Removing AC
Discussion in 'Heating / Cooling Systems' started by prncssgeek, Feb 13, 2008.
  1. prncssgeek
    prncssgeek New Member
    96
    Feb 5, 2008
    Silly Question time:
    How do I get this thing off? I can only find two screws on the inside and I'm assuming that this cover comes off so that you can take the other part off.
    And then that leads to the other question. Once its able to be removed, how do I safely get it off the roof.
    I was reading another thread and saw where someone said to crank it up, pull out the beds, crank it down. That seems reasonable but is it safe? Has anyone tried this? Are there any other suggestions?
    Thanks!
    Lori '63, DH Brian '68, DD Charley '84, DS Zach '05, DGD Anna '03
    80something Coleman Sequoia
    97 Jeep Wrangler "Jesse" TV
    TinekerPup restoration site
  2. suprz
    suprz may you never doubt yourself....
    1,400
    Feb 1, 2007
    i would think it is definitely a two person job. my first thought was to get on a ladder and have the top up and have someone inside crouch down while you crank the top down alittle till the person inside coudl lift it from underneath while you wrestle with it on top while on the ladder? or some sort of scaffold across the top of the PUP just above the roof? so you could get closer to the A/C? unfortunately i have never had to do it. sorry.<img src=../Images/icons/icon_smile_sad.gif border=0 align=middle alt="Sad">
    1996 jeep cherokee 4x4
    2002 flagstaff 228 AKA "cool runnings"
    "just camp!!"
  3. jetrail
    jetrail New Member
    221
    Oct 4, 2007
    edgewater , md
    we replaced my mother in laws on her camper but it was a travel trailer , after getting the inside cover off there should be 4 bolts which hole the ac on the roof after loosening them you will most likely have to crank the top down because the unit that sits on the roof isn't light , i haven't done one on a pup but when we did hers there were 2 of us working on it
    Jay & Lisa
    00 dodge dakota
    97 coleman laredo
    (4) 4 legged children (non camping)
    Luna, Lady, Alley & Azalea
    all girls , all cats lol
  4. prncssgeek
    96
    Feb 5, 2008
    I think you guys are right. It is a two person job. I guess I'll have to do that tomorrow when the DH is home during daylight hours to help. Something tells me though that removing an AC unit was on his list of things to do on Valentines day.
    I'm surely missing something on getting this removed though. I finally got the inside off, found four bolts. These bolts appear to be holding the outside part of the unit on. However, no matter how much I turn them, they don't seem to be coming out. I've felt for nuts on the other side, can't feel any.
    <img src="http://www.1day1world1love.com/pics/albums/ac/normal_DSCF4352.JPG" border=0>
    Its about to drive me crazy. They are loose, they turn just fine. But they aren't coming out. And they are about 8 inches long!
  5. suprz
    1,400
    Feb 1, 2007
    sounds like the nut that the screw ,screws into is turning also. can you see where those screws go to from the outside? take a look and see. you may have to get a wrench in there and hold the nut while someone turns the bolt to get them out. I have had some "captive" nuts on some things that started to turn and to get them to stop turning, i had to put some downforce on the screw while you unscrew it. like fitting a small thin bladed screwdriver between the bolt head and the bracket while you use a socket on the bolt. if there isnt way to get to the nut that is holding that bolt, the only other thing i can think of is to cut the bolt, and once the unit is off you can hopefully get the rest of the bolt out?
    "just camp!!"
    Edited by - suprz on February 13 2008 13:56:52
  6. prncssgeek
    96
    Feb 5, 2008
    Thats what I thought too. But they don't go through to the outside, they end in the top part of the unit. I have felt for a nut, but can't feel one. I'm about ready to take tin snips to the retainer and cut them out. But, DH wants to keep the AC unit in case I ever decide to install it again. I'm just ready to get the thing off!
  7. jetrail
    jetrail New Member
    221
    Oct 4, 2007
    edgewater , md
    i think the bolts thread into the bottom of the unit that sits on the roof, it kind clamps the unit down to the roof
    Jay & Lisa
    00 dodge dakota
    97 coleman laredo
  8. suprz
    1,400
    Feb 1, 2007
    I found this online and it looks like the same opening as your unit. from what i see, they look like the nuts are part of the unit and should not turn.
    http://team.caltech.edu/members/Vehicle/Vehicle/AirConditioning/installation-instructions-8000-series.pdf
    "just camp!!"
  9. Digger
    Digger Foothills of Central Virginia
    2,806
    Nov 27, 2007
    Assuming it is the nut is on the bottom in your picture, can you grab the bolt with a pair of vise grips, hold it steady, and remove the nut? You may want to soak the nut in 3-in-1, or PB Blaster, or WD-40, for a day first.
    Ðigger
    2004 Fleetwood Westlake - StonyBlue
    2002 Econoline E-150
  10. suprz
    1,400
    Feb 1, 2007
    I just called my local fleetwood dealer and spoke to the service manager, he said to try to take the plastic shroud off the unit and see if you can find the bolts and see if there are nuts you can get a pair of vice grips on. if not he said to try putting some down force while trying to unscrew the bolts. (like my previous post) and then he said if all else fails cut the bolt and see it is comes out the other end once the unit is off and you can turn it upside down. but i dont see where that would be of any good when you go to put it back on. you wouldnt have any way to fasten it back down.
    "just camp!!"
  11. prncssgeek
    96
    Feb 5, 2008
    I got it!!! Blasted it with WD-40, took a break. Came back started turning, 3 of 4 started coming out. Number four broke, retaining bracket has been removed!!! I'm so excited!
    Thanks for all the great help! I did find nuts, just not where I was expecting them to be. DD held them with vise grips while I did the rest.
    And the best part? I have enjoyed my first cup of coffee in the camper!
    The fun part will be lowering the top, removing the caulking, and pulling the unit off. There does not appear to be a gasket. I bet thats why there was a leak!
    You guys are great! Thanks again for the help!
  12. suprz
    1,400
    Feb 1, 2007
    Glad you got it! now the fun can really start! <img src=../Images/icons/icon_smile.gif border=0 align=middle alt="Smile">
    "just camp!!"
  13. jetrail
    jetrail New Member
    221
    Oct 4, 2007
    edgewater , md
    just be careful some of those units can be heavy , but im glad it came off for you , what are you gonna put back on the pup a vent , or those vents w/ the electric fan in them ?
    Jay & Lisa
    00 dodge dakota
    97 coleman laredo
  14. prncssgeek
    96
    Feb 5, 2008
    I am ready for the fun!
    The girls want to put in a vent with a fan. I want to go with just a vent and DH doesn't care, he just wants to keep the option of adding the AC unit back!
    More than likely, we will do just a vent. Everywhere we camp is well shaded and there are lots of trees, so we always get a breeze.
  15. FSHNFOOL76
    FSHNFOOL76 New Member
    291
    Mar 31, 2006
    Sound Beach, N.Y.
    I took out my a/c last year and put in a vent/w fan and don't regret it. The fan is reversible and is great for a breeze when nature isn't supplying it.
    http://community.webshots.com/user/fshnfool76
    Alan-'58/DW-ageless<img src=../Images/icons/icon_smile_sarcastic.gif border=0 align=middle alt="Sarcastic">/DD- always the princess <img src=../Images/icons/icon_smile_blush.gif border=0 align=middle alt="Blush">/DS- busy playing gameboy<img src=../Images/icons/icon_smile_tongue.gif border=0 align=middle alt="Tongue">/New Dpuppy-'07/ <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">'88 Coleman Chesapeake/<img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle">'99 Expedition/
  16. prncssgeek
    96
    Feb 5, 2008
    Fshnfool,
    I like the way yours looks. I think it was your pictures that made me really want to go with a vent in the first place. I may have to give in and give the girls the fan.
  17. Wannafishmore
    Wannafishmore New Member
    151
    Sep 23, 2007
    Congratulations on getting that air conditioner off. Sounds like it was very aggravating.
    Gosh prncssgeek, you live down south, are you sure you want to take that air conditioner off and keep it off? Summer's in Texas can be unbearable, I thought Georgia was hot too.
    1991 Starcraft Starflyer
    2001 Nissan Xterra
    portabote
    "Nobody notices what I do until I don't do it"
    Edited by - Wannafishmore on February 13 2008 23:05:17
  18. prncssgeek
    96
    Feb 5, 2008
    I certainly want to get rid of it. DH isn't so sure. The girls have one state park that they go to all the time to camp and it's always cool there. Always a nice breeze. In fact, last summer they came back to the house to get more blankets because they were cold, that was in August. So I think they will be ok without the AC. I am going to keep the unit in case they change their minds.
    Georgia can be horribly hot and they won't always be camping on the lake. Of course if we don't get some rain it won't be a lake much longer, just a big pond! So I'll put the unit in the garage and see what they say in November!
  19. FSHNFOOL76
    291
    Mar 31, 2006
    Sound Beach, N.Y.
    Thanks, good luck with your decision. I know they do make a different kind of cover (shroud) too that allows you to have the fan on when its raining. It's collapsable for travel so that it's not much taller than the regular vent lid. That was about $100 more so I said 'no thanks' and will possibly get that at another time.
