Roof side panel removal help
Discussion in 'Camper Restoration Projects' started by Jason46902, Apr 30, 2019.
  1. Jason46902
    Jason46902 New Member
    Apr 16, 2019
    I have a 2002 aero we just bought. The side panel where the roof latch is on the rear is rotted. Started the removal process today. I have cut all the old caulk, removed the awning and seal where roof and side panel meet. Then on the inside I have removed the screws from the under side of the side panel, roof AC brackets, door, and the metal channel where the canvas is. It's still not loose. Any thoughts or anyone have any experience on this? Thanks for any and all help
  2. Flipped in NH
    Flipped in NH Member
    54
    35
    Sep 6, 2018
    Groveton, NH
    Try a search on the Forums. Lots of info here on roof repairs. Many with photos.
    We haven’t taken our roof apart “yet” so no personal help from me.
  3. Pelagius117
    Pelagius117 New Member
    Feb 6, 2018
    Glendale, Arizona
    Hey Jason,
    I recently had to repair my pop up roof in a similar manner, but i had to do both sides. Mine was held on by a number of small nails along the entire length of the roof. I was able to get mine off by hitting it from the inside out with a hammer close to the roof line. Hope that helps.
    (Ironically my name is also Jason)
    Jason
  4. John Bedsole
    John Bedsole New Member
    18
    Mar 14, 2019
    Atlanta
    I rebuilt all four sides of my Dutchmen 1002xs. I had staples about 1 1/2 inches long all the way down the sides. I used a hand pry bar from lowes and gently pulled the two apart. take your time and you will not damage the roof board.
  5. John Bedsole
    18
    Mar 14, 2019
    Atlanta
    I rebuilt all four sides of my Dutchmen 1002xs. I had stales about 1 1/2 inches long all the way down the sides. I used a hand pry bar from lowes and gently pulled the two apart. take your time and you will not damage the roof board.
