Roof Stuck Open - 1993 Flagstaff 621
Discussion in 'Lift Systems' started by jmbo, Apr 15, 2019 at 11:15 AM.
  1. jmbo
    jmbo New Member
    Monday
    We have a 1993 Flagstaff 621 tent trailer. I believe that this has a Jayco lift system.
    When trying to crank up the roof recently, the crank was only working partially - it would not fully lift the weight, so one person cranked while the other pushed up on the roof from inside. This eventually got the roof extended fully.
    Now the roof is stuck in the fully extended position and will not go down. I have tried using a pipe wrench with quite a bit of force to turn the crank in the down direction, but no luck. Any idea what could be causing it to be stuck? Thanks!
  2. Shaman1
    Shaman1 Well-Known Member
    1,580
    236
    May 13, 2011
    Oklahoma City, Oklahoma
    Try to lift it a little more. Sometimes they will stick.
  3. jmbo
    jmbo New Member
    Monday
    Thanks for the reply, I tried lifting it a bit more previously and it remained stuck. I'll try again this evening.
