running fridge on propane
Discussion in 'Propane - Got Gas' started by RockyRoo, Sep 16, 2013.
  1. RockyRoo
    6,492
    82
    Jun 8, 2012
    Any thoughts on why a fridge might not light on a tank that still has 8 pounds of propane in it, but will on a full tank? I would think the tank with 8 pounds should still have enough pressure to light the fridge.
  2. RetAF
    RetAF Member
    132
    Apr 22, 2010
    Will the tank with 8 pounds in it power your stove and/or water heater? Maybe that tank is bad.
  3. tombiasi
    5,073
    831
    First thing I would have to ask is how did you determine there is 8 pounds in the tank.
  4. RockyRoo
    6,492
    82
    Jun 8, 2012
    Put it on a scale. 18 pound tank weight, 26 on the scale
  5. rabird
    6,545
    247
    TX
    If this is through different hoses as in a dual cylinder setup, yes there could be a problem with one pig tail/ACME connector.
  6. tombiasi
    5,073
    831
    26 on the scale at least indicates there is liquid in the tank. With liquid in the tank the pressure is the same as it would be with a full tank. I can think of no reason for what you describe.
    I'll wait to be educated.
  7. RockyRoo
    6,492
    82
    Jun 8, 2012
    went out today when I got home, opened the offending tank and lit the stove, furnace, water heater and then the fridge. All burned as they should, so who knows. Problem solved I guess, till next time.
  8. bropaul
    bropaul New Member
    4,830
    Aug 7, 2009
    Spider webs... getting ready for Halloween! [;)]
    Diane
  9. efehser
    efehser New Member
    4,614
    Sep 3, 2012
    Gremlins
  10. candleems
    candleems Member
    726
    Jul 12, 2006
    South Central PA
    Air in the line. If my PUP has sat for a month, the fridge is always hard to light. Easier to light the stove first as it is further down the line for propane. Fridge is better once the cobwebs have burned out.
