Rust on drop ball mount?
Discussion in 'Tow Vehicles, Hitch & Towing' started by NoleFan, Apr 18, 2019.
  1. NoleFan
    NoleFan Member
    31
    Jun 28, 2017
    Our new to us PUP sits perfectly level with a 5 1/4" drop on my wife's Yukon. Luckily my father in law had an old one that he had no idea where it had come from.
    The thing is a little rusty, but no big deal, I figured I would clean it up and pit a new ball on.
    BUT the shaft that goes into the hitch has some rust pits (not all the way through by any means). I know this thread is useless without a picture, and I can get one tonight.
    What are your thoughts, should I sand the rust down and paint this drop hitch, or just trash it and get a new one? My pup weighs less than 2000lbs, but I want to be safe with it on the road. No cracks or anything.
  2. nineoaks2004
    6,826
    2,739
    Graceville, Florida
    It would be hard to tell the damage until you get the rust taken off, if it is just very shallow pits you should be ok. If they are deep it might cause a problem.
  3. BikeNFish
    BikeNFish Well-Known Member
    2,564
    1,537
    Apr 24, 2017
    Maplewood, MN
    I would take a steel brush to it after I sprayed it down with some WD40. Then wipe it down with a rag.
  4. rabird
    6,545
    247
    TX
    Use it AS IS.
  5. NoleFan
    NoleFan Member
    31
    Jun 28, 2017
    Here it is:
    With a new ball and cleaned up, is it good as-is or trash?
  6. WrkrBee
    WrkrBee Well-Known Member
    1,920
    718
    Wire brush it down, paint it, and go camping.
    Blackripley likes this.
  7. tombiasi
    5,080
    832
    That will probably be OK but that is not surface rust and a new one is about 20 bucks.
  8. rabird
    6,545
    247
    TX
    AS IS
  9. xxxapache
    2,742
    761
    I would use it as is..it may get stuck. The very least I would do is wire brush off the rust and spray it with some kinda oil or lube.
  10. Anthony Hitchings
    294
    96
    Mar 2, 2019
    replace it
    durhamcamper likes this.
  11. Wakita46
    Wakita46 Active Member
    220
    48
    Mar 15, 2013
    I might use it for a short trip but I would replace it as soon as I could.
  12. MNTCamper
    MNTCamper Active Member
    778
    139
    Jun 14, 2014
    Clean and recoat, that is mostly surface rust. A rust resistant primer under black coating would help a lot. May need to prime with rust reformer type primer.
  13. J Starsky
    J Starsky Well-Known Member
    649
    423
    Aug 3, 2017
    East Central MN
    My 4in angle grinder, a flap disc and some rustolium would solve that. Lots of grease shall be used when you insert into a hitch.
    xxxapache likes this.
  14. NoleFan
    NoleFan Member
    31
    Jun 28, 2017
    I am actually surprised by all of the fix it comments! Thanks everyone, will get it cleaned up, painted, and keep her lubed!
  15. kcsa75
    kcsa75 Well-Known Member
    2,540
    1,074
    Sep 9, 2013
    Kansas City
    I would have no problem using that. Hit with a wire brush and a can of black Krylon and you should be good to go. I wouldn't worry about replacing the ball either, unless it's not there, not the right size or is badly damaged.
    NoleFan likes this.
