Sag in water tank bottom
Discussion in 'Miscellaneous Repairs & Maintenance' started by Jonson01, Jun 21, 2019.
  1. Jonson01
    Jonson01 Member
    36
    Sep 4, 2018
    Southern IL
    Finally getting the pup opened and dewinterized but that's what having twins will do!
    Does anyone else have a sag to the fresh water tank on the bottom of tank? It makes it harder to drain. My remedy was to use a board and bottle jack. But even with this I looked and the drain is not actually the low point and there is still liquid in the bottom 1/4"-1/2". Any thoughts on this?
  2. tfischer
    tfischer Well-Known Member
    3,318
    842
    May 21, 2014
    All tanks are like this. It doesn't hurt anything... just flush it out and re-sanitize it if you don't use it for a lengthy time.
    Jonson01 and Sjm9911 like this.
  3. Sjm9911
    3,615
    1,747
    Mine doesn't drain completely eaither. I just run water in it as said to flush it all out before a trip.
    Jonson01 likes this.
  4. Fless
    Fless Active Member
    930
    184
    Aug 14, 2012
    Colorado
    When I drain mine I put it on an incline in the driveway, with the drain port low. That helps get out more than usual.
  5. Orchid
    Orchid Sharp Shootin' Grandma
    5,113
    1,777
    May 8, 2011
    Florida by way of WV and MD
    I'm just curious how you even know this. I can't see mine. Maybe if I crawled underneath?
  6. tfischer
    3,318
    842
    May 21, 2014
    We often leave the drain open all the way home from a campsite, so more can come sloshing out.
    Orchid, bheff and Jonson01 like this.
  7. Jonson01
    Jonson01 Member
    36
    Sep 4, 2018
    Southern IL
    Mine is pretty exposed under the floor.
    Orchid likes this.
  8. CampingFamily1
    CampingFamily1 Active Member
    586
    62
    May 12, 2007
    Minneapolis/St. Paul, MN
    We thought about doing this, but then thought about all the dirt that might get spashed up into the nicely sanitized water tank.
  9. Orchid
    5,113
    1,777
    May 8, 2011
    Does the water tank auto-fill, like the hot water heater, when hooked to city water? Or do you have to just fill from the cap on the side of the trailer. We have never used ours, that I know of. If it auto fills, then maybe we have.
  10. Jonson01
    Jonson01 Member
    36
    Sep 4, 2018
    Southern IL
    Fills separately.
  11. tfischer
    3,318
    842
    May 21, 2014
    I don't think it's significant. Opening is like 1/4"-3/8" and does a 90 degree bend before it enters the tank. Plus it's nowhere near the wheels on mine.
