Save me some grief...Dometec AC...
Discussion in 'Heating / Cooling Systems' started by myride, Aug 4, 2018.
  1. myride
    myride Well-Known Member
    772
    347
    May 14, 2015
    Edmonton, AB
    Can't toggle my AC switch to off on my Dometec 2193, if I unplug the AC from the 110 receptacle will it still run on LP or am I missing the obvious.
  2. myride
    772
    347
    May 14, 2015
    Edmonton, AB
    I think I overlooked the obvious...when I have dry camped I've ran the reefer on LP...."no power"...Duh....guess this would answer my question....lol
  3. nineoaks2004
    6,636
    2,586
    Graceville, Florida
    Air Cond. needs 120 VAC, either plug in on the site or run a generator.
  4. myride
    772
    347
    May 14, 2015
    Edmonton, AB
    Sorry, when I said "AC" I was meaning 120VAC for my refrigerator. The 120 switch will not toggle off so I have just unplugged it from receptacle and switched to propane.
  5. joet
    4,129
    714
    Replace the rocker switch
  6. myride
    772
    347
    May 14, 2015
    Edmonton, AB
    Yup....
    Just what I was thinking, thanks.
  7. PopUpSteve
    PopUpSteve Administrator
    18,376
    1,272
    Dec 22, 2002
    Malvern, PA
    That's pretty weak is the rocker switch failed. Think about it, the unit may be 14 plus years old, but how many times has it rocked back and fourth in that period of time? Sure, it's kind of exposed to the elements but that switch should not fail in that camper's lifetime!
  8. myride
    772
    347
    May 14, 2015
    Edmonton, AB
    True Steve but when I move it to "off" she just pops back on....hence having to unplug 110 ac when switching to propane.
  9. emoney
    emoney Well-Known Member
    880
    447
    Jul 7, 2018
    End of the day, it’s not like the manufacturer took the “highest bidder” in the rocket switch bid. Coincidentally I’ve had more switches go bad in the past 4-5 years on various things from the pressure washer to the little air compressor to what I thought was a pretty good chop saw.
  10. myride
    772
    347
    May 14, 2015
    Edmonton, AB
    I hear ya emoney.....first thing to do is replace rocker switch...
