Seized gas control knob, Dometic 2193
Discussion in 'Refrigerators and Coolers' started by Dave Brick, Jun 29, 2017.
  1. Dave Brick
    Dave Brick El Cheapo Family Camper
    137
    33
    Nov 29, 2010
    Family is heading out dry camping in the Adirondacks after the 4th. I got a new propane tank for the trip, connected it, and tried a dry run in the driveway. When I tried to turn the gas control knob to High, it was very stiff. I pulled off the plastic knob and found out I had mostly stripped it! Tried to turn the brass part under the plastic knob with channel locks and couldn't move it. It wouldn't push down for lighting either.
    Broke out the PB blaster, sprayed it on, tapped it a little, and then tried the vice grips. Got it unstuck with some difficulty. Sprayed more, tapped more, turned it more, and eventually it got unstuck, and even pushed down properly. Lit the fridge without difficulty, let it run for several hours, fridge got nice and cold.
    I guess the vice grips now need to be in my camping toolbox. Otherwise, a happy ending.
    Has anyone else gotten this knob seized?
  2. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    It sounds like the valve needs to be disassembled and cleaned and new gas valve grease applied.
    nineoaks2004 likes this.
  3. northpoletim
    northpoletim New Member
    Jun 4, 2019
    I have this exact issue of a seized gas control knob, and wondering how to fix it. I can move it, but it's really stiff. And when depressing it to light, it won't spring back without me pulling it back up.
    Wondering:
    1. Does the knob just pull off if I lift it with enough pressure?
    2. What's involved in dissembling the valve and applying new gas valve grease? I'm somewhat handy, but gas lines scare me :)
  4. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    I'm not sure. I think they are all different.
  5. northpoletim
    Jun 4, 2019
    Quick followup in case it helps others...
    I wasn't able to easily remove the gas control knob, so tried squirting some 3-in-1 Lock Dry Lube under it. To my surprise, it immediately starting rotating and depressing normally. I couldn't believe it ended up being that simple, at least in this case. Hope this helps someone!
