September 2009 Recipe of the Month
Discussion in 'Recipe of the Month' started by PopUpSteve, Aug 30, 2009.
  1. PopUpSteve
    PopUpSteve Administrator
    17,853
    945
    Dec 22, 2002
    Malvern, PA
    Title: Lasagna (12" Dutch Oven)
    Member: [CK] Beerlifter
    Serving Size: Feeds an Army.
    Ingredients:
    2 lbs. Hamburger meat (browned and drained)
    1 lbs Sausage (browned and drained)
    Lasagna noodles (1 package)
    2 lbs Cheese (more or less, however cheesy you like it)
    2 large jars of spaghetti sauce
    Directions:
    • In a 12 inch Dutch Oven pour just enough sauce in the bottom to
      cover it.
    • Sprinkle meat and sausage on top of sauce to about 1/4 in thick.
    • Sprinkle cheese on top of that.
    • Break noodles in half to fit in Dutch Oven and cover first layer.
    • Repeat till Dutch Oven is about 1 inch from top or out of Ingredients.
      Ending with cheese on top.
    Place a ring of coals around the bottom and a ring and a half around
    the top. This is right at 350 degrees.
    Cook Time: Cook for about 45 minutes checking every once in awhile just to show off! Check noodles for done. Then serve.
    Notes: This will feed an army so invite your
    camping neighbors!!
    Comments and Thoughts Welcome!
  2. hvac1877
    hvac1877 Old Dominion Iron Chefs Highland Springs, Va
    2,880
    41
    Mar 10, 2008
    Highland Springs Va
    It will look like something like this. I used a similar recipe not as much meat.
  3. Sallymander
    Sallymander New Member
    18
    Apr 9, 2008
    Barrie, Ontario
    Sounds delicious! What kind of noodles do you use? Cooked or "oven ready"?
  4. hvac1877
    2,880
    41
    Mar 10, 2008
    Highland Springs Va
    I used the Kroger Lasagna noodles in the green box. They are not pre-cooked. Broke the noodles and placed in the DO
  5. TexasCamperMom
    TexasCamperMom New Member
    39
    Jun 18, 2009
    Wylie, TX
    What kind of cheese? When we normally make Lasagna, we use Ricota and provolone. Would that work?
  6. hvac1877
    2,880
    41
    Mar 10, 2008
    Highland Springs Va
    This is the recipe i got from JU-DI I will add more meat next time but still turned out great!!!!!
    DO Lasagna
    1 1/2 lb lean ground beef
    23 oz spagetti sauce
    9 oz shredded mozzaella cheese
    3 eggs
    2 1/4 C cottage or ricotta cheese
    1/4 C grated parmesan cheese
    13 lasagna noodles
    1 1/2 tsp oregano
    3/4 C hot water
    Prehead DO. Brown the ground beef. When done, remove the beef to a large mixing bowl. Add spagetti sauce (I used Prego) to beef and mix well. In another bowl, add the cottage or ricotta cheese, Parmesan cheese, mozzarella cheese (reserve some for topping), eggs and oregano and mix well.
    Layer in DO as follows:
    4 noodles broken
    1/3 meat mixture
    1/2 cheese mixture
    5 noodles broken
    1/2 remaining meat mixture
    remaining cheese mixture
    remaining broken noodles
    remaining mozzarella sprinkled
    on top
    Pour hot water around the edges of the DO. Cover and bake for one hour. Check frequently.
    Hint: 12 briquettes on top, 12 on bottom. I added more on top during the last 10 minutes to brown the top layer of mozzarella.
  7. Beerlifter
    Beerlifter Oklahoma, It's not just for Indians anymore!
    878
    Jun 22, 2006
    Oklahoma City , Oklahoma
    I usually use Barfilla uncooked lasagna noodles. I break them in half so they will fit in the dutch oven. Usually 2 noodles will make a layer in a 12 in DO.
    As far as the cheese goes..what ever type you like. I'm sure it doesn't matter. Experiment, that is how I came up with mine!!!
    Here is a pic of mine. Done and ready to eat.
  8. hvac1877
    2,880
    41
    Mar 10, 2008
    Highland Springs Va
    Looks great!!!!!!!!!!!!!!! I was surprised how good it was. There was none left when we made it.
  9. Beerlifter
    878
    Jun 22, 2006
    I'll have to admit I was a little concerned about useing the noncooked noodles the first time! Everything came out perfect. There are 4 of us and we couldn't finish it all so we started asking camping neighbors that had come by to see what we were cooking if they would like to have some!!!
  10. Nitty Gritty
    Nitty Gritty I love RVing!!
    196
    Jun 18, 2007
    Tornado Alley, Oklahoma
    I have had Beerlifter's Lasagna made by Beerlifter himself and it is very good!
  11. Beerlifter
    878
    Jun 22, 2006
    Well ty Angie!! I really enjoyed the trout from roaring river. Maybe you should post the recipe for that!!! It was awesome!!!
  12. Miller Tyme
    Miller Tyme N. Fond du Lac, Wis.
    175
    Jan 7, 2003
    North Fond du Lac, Wisconsin
    Another vote for Steve's lasagna! [:D]
    Only suggestion...for more than 10 campers, maybe make a second batch..... [;)]
  13. emssmiley2002
    emssmiley2002 Florence,Ms
    196
    Mar 10, 2009
    Mississippi
    Thats the exact recipe I use. The only difference is I have the 14" D.O. HVAC is right it does fed any Army! :) [:)O] [:)O]
  14. Sharon
    Sharon Dover, FL
    1,748
    Oct 28, 2008
    Dover,FL
    Oh Man! That looks so good! Thanks for the recipe.
    I have not been camping since I got my DO so looks like im going to have to try it in the back yard.
    Sharon
  15. Nitty Gritty
    196
    Jun 18, 2007
    Johnathan made the trout, Steve. He never uses exact measurements of anything.
  16. taxguy
    taxguy Sandusky, OH
    74
    May 15, 2009
    Sandusky
    We tried the recipe over the weekend. Maybe we didn't use enough sauce, but I think we will use oven ready noodles next time. Dutch oven cooking is great - just experiment and find out what works for you!
  17. gypsy32
    gypsy32 God bless the U S A
    197
    Mar 22, 2009
    CHEEKTOWAGA ,NY
    well looks and sounds good i hope to try and get it to turn out as good
  18. NonnieMa
    NonnieMa New Member
    Sep 23, 2009
    Rensselaer, NY
    My husband made this one weekend and it was better than what I make. Pot Roast another nite I love the Dutch oven lovin as he calls it
  19. Tekboy46
    Tekboy46 Member
    979
    Aug 15, 2007
    Central Oklahoma
    Judy cut this recipe in half for the two of us and baked it in the "indoor" oven at home in a Pyrex dish. Came out perfect and we still had leftovers! No reason a half recipe shouldn't work in the D.O. When I try this outdoors I'll let yaz know what happens.
  20. hvac1877
    2,880
    41
    Mar 10, 2008
    Highland Springs Va
    I will cooking this in two weeks at my friends campout. Will have 3 do with lasagna!!!!!!
