So excited to join the pop up community
Discussion in 'Introduce Yourself' started by rpjjma, May 23, 2019.
  1. rpjjma
    rpjjma New Member
    May 23, 2019
    Hello -
    I purchased a 2009 Palomino Y Series pop up off of Craigslist! The seller put it through a 45 point inspection but couldn't show me how anything worked, at first I thought he was scamming me... but then based off of several visits and phone conversations - came to realize that he just truly didn't know much about the technical aspects. I'll admit I have limited knowledge too but learn best by doing. Took a risk and got it home - everything seems to work!
    We are really excited to have this thing and make it our own. I plan on going through some of the threads here to actually learn how everything works. The biggest confusion I have right now is what goes off propane vs 12V vs 120 and if my battery is "fresh" or not. As well as how long everything will last for. Just found out how to access the controls to the fridge from the outside panels (previous owner had no clue).
    Taking it out this weekend to a friend's property for a trial weekend.
    -Ryan from Colorado
    Orchid and Kitrina like this.
  2. WrkrBee
    WrkrBee Well-Known Member
    1,746
    635
    Welcome to the Portal from South Carolina. Use the "Search" feature on the Portal. There are many discussion that should answer your questions.
  3. PopUpSteve
    PopUpSteve Administrator
    18,409
    1,287
    Dec 22, 2002
    Malvern, PA
    Welcome to PopUpPortal
  4. Kitrina
    Kitrina Member
    34
    Mar 31, 2019
    DFW TX Area
    Welcome!
  5. GalsofEscape
    GalsofEscape Active Member
    691
    151
    Nov 26, 2013
    Maryland
    welcome to the portal - the best thing about camping, there are alternatives if you can't figure out how the stuff in the camper works right away. The cooler will suffice for a non-working fridge, a lantern will replace the lights, and a jug will hold water which you can heat on the stove..... so enjoy your first outing with your NTU camper and figuring out how it all works...
  6. nineoaks2004
    6,661
    2,602
    Graceville, Florida
    Welcome from N/W Fl panhandle. Congrats on the NTU PUP. Do not worry everything will come to you and you will become expert any part of the unit. Just go slow and take your time, also ask questions is you get confused. Good Luck and Happy camping
  7. kcsa75
    kcsa75 Well-Known Member
    2,443
    1,000
    Sep 9, 2013
    Kansas City
    Hey Ryan. Congratulations on the NTU Pup and Welcome to the forum from Midway USA.
  8. joet
    4,150
    721
    Welcome from the mountains of West Virginia
  9. megcabra
    megcabra Well-Known Member
    1,583
    401
    Aug 12, 2015
    Chapel Hill, North Carolina
    Welcome and greetings from North Carolina to the exciting world of Pop-Up camping!
  10. Raycfe
    14,399
    1,072
  11. BikeNFish
    BikeNFish Well-Known Member
    2,478
    1,443
    Apr 24, 2017
    Maplewood, MN
