solar panel replacement cord/ repair
Discussion in 'Wiring' started by Katskamper, Sep 16, 2018.
Tags:
  1. Katskamper
    Katskamper Active Member
    730
    181
    Nov 21, 2015
    Fort Worth, TX
    FFB169A4-86F6-4871-9531-8A2229417134.jpeg 7669B154-01D0-44E9-AA7D-E3CB14E29327.jpeg 7203EDC6-8D0E-47EF-975A-FE7636B7E1F4.jpeg
    ordered new 25ft dual quick plug cord.
    marked the end that pairs with battery BATT.
    option a.
    use Batt end on battery, cut off xxx end, add ring terminals.
    result 25 ft cord.
    option B
    cut off xxx end & flip end to match polarity on battery end, so i keep the inline fuse (red 10#)
    result 15ft cord
    option c.
    get the other end for fuse cord so new cord plugs in?
    cut off xxx end and use connectors to create 40ft cord.
  2. joet
    3,561
    515
    Kat, I used Anderson SB 50 connectors with 75ft of 10-2 SO cable. I have a Anderson connector on a pigtale sticking out of the battery box. I can move the panels to catch the optimum sun.
  3. Katskamper
    730
    181
    Nov 21, 2015
    Fort Worth, TX
    ! this part did not show up in my original search!
    running around the corner to get it!
    now i will have a REALLY long cord!
    sun is out & should be able to recharge battery!
  4. Katskamper
    730
    181
    Nov 21, 2015
    Fort Worth, TX
    despite the website saying it was in stock, it wasnt.
    autozone had something close.
    now cord is 40 ft!
    reaches from garage to side yard for afternoon sun.
    battery is depleted
  5. Katskamper
    730
    181
    Nov 21, 2015
    Fort Worth, TX
    friday after thanksgiving purchased new battery.
    old one hada bulge - had to go.
    was so cloudy this weekend the solar panel wasnt used.
  6. nineoaks2004
    5,692
    2,011
    Graceville, Florida
    I hope it works after all the trouble you have been thru trying to get everything to work. Personally I carry a small genny and charger to re-charge my batteries (if I am boondocking)
    I built and installed solar school flashers and count stations for several years, and when we had several days with no or hardly any sun, I would get complaints.
