Suspension Air Bags
Discussion in 'Tow Vehicles, Hitch & Towing' started by mattlreese, Aug 8, 2018.
  1. mattlreese
    mattlreese Active Member
    133
    32
    Sep 6, 2017
    I tow a 2500 lbs popup camper with a 2018 Chrysler Pacifica Mini-van. Towing is find but It has about 2 inches of sag and I would like to install air bags to help. Unfortunately, there are no air bags out yet for my van.
    Has anyone had any luck installing universal fit air bags and has a recommendation for me?
    Also please do not post if you are say something negative about mini van towing. The van tows the popup just fine and I have not had any issues. I just want to make sure I have the best towing setup possible.
  2. WrkrBee
    WrkrBee Well-Known Member
    1,185
    418
    I had an old Mercury Villager that I had to take to a spring shop and had a helper spring added to each side.
  3. SteveP
    SteveP Well-Known Member
    1,127
    236
    Contact the customer service for the brand bag you want to use. It's possible that the parts for the 2017 model will work unless there's been major changes for the Pacifica suspension.
    sstressfl likes this.
  4. mattlreese
    133
    32
    Sep 6, 2017
    @ SteveP, the 2017 model was the first year the van was out and no no one has those either sadly.
  5. sstressfl
    sstressfl New Member
    19
    Jul 4, 2018
    Vermont
    You should call a Chrysler dealer and see if the rear coil part numbers changed from the older model to the new Pacifica. If the part is the same, it's a good chance the air bags designed to fit the older Grand Caravan would fit.
    (Oops, I just saw SteveP's reply above... ditto!)
