T Train Coleman Utah
Discussion in 'Camper Restoration Projects' started by Stang65fst, Jan 18, 2018.
  1. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    IMG_20180130_205647.jpg IMG_20180130_205640.jpg IMG_20180130_205620.jpg IMG_20180130_205609.jpg
    jnc likes this.
  2. kmbarreiros
    kmbarreiros Member
    39
    Jun 17, 2014
    Fairhaven, MA
    Thanks, I am going to try and hobble out there soon to get a picture and a reminder of exactly which wire it was.
  3. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    I can get you better picture of the plug if that is helpful. I do not have a furnace nor a water heater. Just let me know. Will probably have it closed up by the weekend. More than happy to help especially since there is NOTHING out there.
  4. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
  5. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    Time to ditch the ridiculous hatch door and power cord. Should also open up a cabinet inside for storage. IMG_20180202_145136.jpg IMG_20180202_145125.jpg IMG_20180202_145112.jpg IMG_20180202_145103.jpg IMG_20180202_145057.jpg
    silvermickey2002 and Orchid like this.
  6. kmbarreiros
    kmbarreiros Member
    39
    Jun 17, 2014
    Fairhaven, MA
    Thanks for all the pics yours is starting to look a little different then what I have.
    The snow is almost gone here so I plan to get out to my camper and take a look and a picture.
  7. kmbarreiros
    kmbarreiros Member
    39
    Jun 17, 2014
    Fairhaven, MA
    Ok here is the connector I am referring to. It is the one that was connected to the water heater in the Front compartment. It is a 3 pin connector with a White, solid Black and Green wire. The Black wire is the one I referring to.
  8. kmbarreiros
    kmbarreiros Member
    39
    Jun 17, 2014
    Fairhaven, MA
    Well after looking at the pictures in the beginning I don't think you have this connector or a hot water tank up there.
    Looks like I may be opening a new thread about this.
  9. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    I do have that connection, I will get a picture of it for you. You are correct I have no water heater.
  10. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    ryguyFam likes this.
  11. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    Side is back on and outlet is in and working. The porch light didn't fair well so have to get a new one. IMG_20180211_064939.jpg IMG_20180211_072955.jpg
  12. kmbarreiros
    kmbarreiros Member
    39
    Jun 17, 2014
    Fairhaven, MA
    You may be right that connector maybe for something else.
    You build is very inspiring I can't wait to be able to start working on mine. It sucks being home for the next 2-3 months and can not do basically anything(I did end up getting 2 screws in my ankle).
    How are your back corners? I only noticed afterwords that my rear drivers side corner floor was also really saturated and will have to replace a chunk there.
    I plan to remove all the rest of the cabinets and even the slide out to put down new vinyl flooring. I have a friend who has a whole roll for me says it is enough to do the entire floor.
  13. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    They don't look great but they are holding at this point I want to make sure we use it and then I will probably get the entire floor ripped out and redo it all. Right now just need to get it ready to camp with the family.
  14. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    Test fit IMG_20180212_144518.jpg IMG_20180212_160555.jpg IMG_20180212_144555.jpg IMG_20180212_144522.jpg
  15. Halford
    Halford Well-Known Member
    2,905
    236
    Sep 28, 2011
    Santa Clarita, California
    do mine, do mine, do mine! I am first in the line for Stang to replace some of my cabinets and wall...
    Stang65fst likes this.
  16. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    So my porch light was toast due to age so I decided to do the "Euro style" porch light found on Coleman camper parts. I have ordered other parts from them and they arrived quickly. Same with this order I also ordered the LED bulb to put in. After getting wires soldered and putting on the heat shrink. As I was mounting it the top of the light will not sit flush to the side of the camper sticks out about 1/16 to 1/8 inch. Which is frustrating silicone will not and is not meant to fill a gap this size. No gasket is with this light so I will have to make my own. I understand that the side of the camper might be warped slightly but not impressed with this light. Also put 3 new holes to get it mounted as using existing holes were not an option. I will make it work properly but my satisfaction with this product is low.
  17. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
  18. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    Had to add some wood for the next phase to attach to. Had a little help. IMG_20180225_164042.jpg
    jnc likes this.
  19. Stang65fst
    Stang65fst Member
    90
    33
    Dec 13, 2017
    Iron Station, NC
    Finally sealed up, box to come next. IMG_20180309_112332.jpg IMG_20180309_123426.jpg IMG_20180309_123417.jpg IMG_20180309_134453.jpg IMG_20180309_134443.jpg IMG_20180309_144720.jpg
  20. Halford
    2,905
    236
    Sep 28, 2011
    what will you do with the space where the storage was?
