Tension rods, no way
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by RESTLS, Jun 19, 2019.
  1. RESTLS
    RESTLS New Member
    Jun 12, 2019
    Urbandale IA
    Tension rods are just that TENSION rods. I do not trust them. Why? They are TENSION rods relying on tension. Any shift in a camper could cause the tension to fail. We have one in our tub/shower and it fell. Not a good situation. Being a wood worker as a hobby, I have the tools to create a more substantial shelving solution. Noting the attached pictures, I created a PVC system that will not fall.
    I used PVC pipe to create the standards on which the wire shelving bracket are attached. I sanded the lower pole ensuring it slid easily into the upper pole. Pole caps were glued and screwed to the cabinet base and ceiling. Yes, I have no fear of screwing, 1/2” screws into the ceiling.
    A D ring was used to hold the poles in place. The total pole length was ¼” shorter than the distance between the base and the ceiling allowing no pressure on the ceiling.
    The assembly is dismantled, removing the D ring and the assembly and shelves are placed on the table/bed area for storage during PUP collapse.
    Orchid, hayyward and Sjm9911 like this.
  2. Orchid
    Orchid Sharp Shootin' Grandma
    5,118
    1,783
    May 8, 2011
    Florida by way of WV and MD
    Very nice, neat and solid looking! I did have the tension rod version in one of our old campers. I solved the problem by gluing rubber "cups" for lack of a better word, that held the rods from moving. Now we just use pre-made metal shelving over the stove, but what you have made provides much more storage. I may try something like this over a small counter that we have. It doesn't do anything but collect junk right now.
  3. Sjm9911
    3,625
    1,763
    Looks good , but my tension rods are also good. And hold the same, so to each his own. Btw, i recently had a peak at some other campers that really went the extra mile woth there woodworking skills. Nice mortise and tenon joints, pretty wood. At the end of the day its what works for you. Yours is an a + also.
    CarlaCB, Tulip and Orchid like this.
  4. hayyward
    hayyward Active Member
    238
    110
    Sep 16, 2006
    Packerland
    Very nice!
  5. nineoaks2004
    6,819
    2,736
    Graceville, Florida
    Looks really sturdy and a very neat job of doing it. Should work just fine for you.
  6. JWeible
    JWeible Active Member
    107
    53
    May 11, 2015
    Looks great!This is our plan as well. My husband did not like the tension rod idea but liked the shelving. He’s also ok with screwing a few holes in the ceiling, it’s not the roof! Just hoping to get it done before our big trip in August!
  7. tfischer
    tfischer Well-Known Member
    3,318
    842
    May 21, 2014
  8. LittleBrother
    LittleBrother New Member
    Feb 1, 2017
    Glenn Dale. MD
    Used tension rod method, screwed and glued the closet rod holders to the counter top and ceiling. Three years now and never an issue. I do occasionally have to adjust the length of the rod +/- .5" to accommodate the ceiling height; it's an old camper so not sure why it changes occasionally but not something I'm really worried about figuring out.
    Glad you found a solution that worked for you
  9. tfischer
    3,318
    842
    May 21, 2014
    I always collapse ours to the minimum length anyway for storage.
    LittleBrother likes this.
