Thermostat recess / niche
Discussion in 'Miscellaneous Repairs & Maintenance' started by Quackerjacks, May 19, 2017.
  1. Quackerjacks
    Quackerjacks New Member
    Aug 17, 2016
    Our 2009 Viking has the thermostat in the leg area of the dining bunk and it sticks out and gets banged around a lot. Is there a place to buy one of the inserts to recess the thermostat to be flush with the rest of the bunk?
  2. theseus
    theseus Centerville, OH
    2,802
    391
    Feb 6, 2007
    Centerville, OH
    If you call a dealer you could ask. I am sure you can get one, but I haven't located the combination of words to find an online seller to buy one from.
  3. mstrbill
    mstrbill Active Member
    688
    144
    Mar 17, 2013
    Austin , Texas
    Seems like it would be very easy to make one. You could use masonite, 1/4 in plywood or Lexan and glue it together.
  4. kitphantom
    11,557
    741
    We made a similar recess for the fire extinguisher on our first popup, out of wood. We abandoned the thermostat niche on our Coleman though - it was difficult for me to reach, and moving it to the counter reduced the temperature swing by a huge amount. At the same time we added a plug/long wire so it would reach the counter, and changed to a digital 'stat with a momentary back-light.
  5. Boatnman
    Boatnman Well-Known Member
    1,444
    324
    Jan 19, 2017
    western Colorado
  6. Fless
    Fless Active Member
    930
    185
    Aug 14, 2012
    Colorado
  7. Quackerjacks
    Aug 17, 2016
