Thermostat Replacement
Discussion in 'Heating / Cooling Systems' started by Bottom End, Dec 12, 2017.
  1. Bottom End
    Bottom End Member
    34
    Aug 22, 2012
    Hey Everyone
    Below is a picture of my thermostat. It is a heat only thermostat.
    The "on" switch broke and I need to replace the thermostat.
    I would like to replace it with a Digital one if possible. Maybe even one I can place a remote temperature sensor higher than where it is currently located near the floor.
    Any suggestion would be greatly appreciated.
    Thanks
  2. kitphantom
    11,542
    734
    We did this mod in both our pup and the TT. A simple Lux thermostat, with a momentary back light (has batteries) is what we bought, found on Amazon. We used a plug and long wire so we could use it when needed, and place it on the counter. That really minimized the temperature swings, which were huge when it was in a niche 4" off the floor. Note: the first, Hunter, thermostat we bought at Lowe's for the TT worked OK, but didn't have the momentary back light, after a year or so of having to use a flashlight to set the thermostat at night, we bought another Lux.
    DH eventually mounted the thermostat on a piece of wood, with tiny cup hooks on the top, and we hung it on the wire shelving unit.
    MaeKay likes this.
  3. BaysideJim
    BaysideJim Member
    145
    May 5, 2015
    Denver, Colorado
    there are several threads that discuss this in detail.... it is a great easy mod and takes a few minutes and some basic skill with a great payoff much more accurate than the atwood thermos and the light is really nice
  4. Fless
    Fless Active Member
    930
    184
    Aug 14, 2012
    Colorado
    @Bottom End, check out the one I have for sale in the For Sale forum. Would make for a nice tethered T-stat.
  5. MaeKay
    MaeKay Active Member
    613
    216
    Oct 18, 2017
    Utah
    Is this the thermostat you used?
    LuxPro Digital 2 Wire Heat Only Thermostat - PSD010B https://www.amazon.com/dp/B002SR9PHM/ref=cm_sw_r_cp_api_fQKVAb95FPB0G
  6. kitphantom
    11,542
    734
    MaeKay likes this.
  7. Fbird
    Fbird Active Member
    262
    113
    Sep 10, 2017
    Ferndale MI
    I installed this one last fall.
    MaeKay likes this.
  8. lquinn1
    lquinn1 Member
    70
    19
    Aug 17, 2017
    Champaign, IL
    MaeKay likes this.
  9. nineoaks2004
    6,819
    2,736
    Graceville, Florida
    I replaced an analog (mechanical type) with a Honeywell 69-2384ES-01mRTH111
    Non-Programmable Thermostat
    It only uses 2 wires, took a few minutes to install (uses batteries in the stat)
    I bought at Wally World for under $20.00
    And made a big difference in the TT. I use it for heat only.
    Hope this helps Good Luck and Happy Camping
    MaeKay likes this.
  10. MaeKay
    613
    216
    Oct 18, 2017
    Utah
    Oh joy. Now the furnace won’t ignite tonight. The blower turns on, I don’t even hear the clicks I usually and no louder sound when it ignites. And then the fan turns off. I lit the propane stove to see if we still had gas and the fridge is still cooling so I don’t think we ran out of propane.
  11. MaeKay
    613
    216
    Oct 18, 2017
    Utah
    Actually, I read through some previous posts. We flipped the reset button and turned it back on and it works now! Why would it have turned off? We didn’t even have to relight the pilot as far as I can tell.
  12. Fless
    Fless Active Member
    930
    184
    Aug 14, 2012
    Colorado
    Glad the reset worked. Your PuP is new enough that the furnace has electronic ignition, so no pilot. Nice feature!
    _
    MaeKay likes this.
  13. MaeKay
    613
    216
    Oct 18, 2017
    Utah
    Yeah, I realized that what we were trying to light was the water heater. Whoops!
