Tire and Wheel Swap
Discussion in 'Etrailer.com Trailers and Towing Forum' started by robertdonna, Aug 12, 2018.
  1. robertdonna
    robertdonna New Member
    25
    Jun 26, 2018
    Childersburg, Al
    I have a 1996 Coleman Yukon. It came with 10" wheels.
    My question is, has anyone changed their 10" wheels for 13". Is there enough clearance without modifications.
    Thanks in advance..
  2. Matt Benoit
    Matt Benoit Active Member
    410
    228
    Jul 30, 2017
    Warren, MI
    This is very trailer specific. I'd suggest measuring the clearance you have between the top of the tire and the fender well. Start there.
    Rusty2192 likes this.
  3. robertdonna
    25
    Jun 26, 2018
    Childersburg, Al
    Thanks
  4. Rusty2192
    Rusty2192 Active Member
    748
    239
    Jul 30, 2014
    Kentucky
    When checking the clearance, get a heavy friend to bounce on the step or bumper to simulate bumps and watch for clearance there too. I upsized the tires on mine and they have plenty of room during normal travel, but can and do rub the wheel wells on really big bumps. I’ll go down a size next time I’m due for tires.
  5. robertdonna
    25
    Jun 26, 2018
    Childersburg, Al
    What size are you using now???
  6. Rusty2192
    748
    239
    Jul 30, 2014
    Kentucky
    When I bought mine it had 5.7-8 (18” diameter) on it with a load rating barely enough for the dry weight. I bought some 5.3-12 (22” diameter) based on the brochure from my model year, but that must have been wrong, at least on my little 8’ pup. I’ll step down to 4.8-12 (20.5”) next time, which should buy me the clearance I need.
  7. robertdonna
    25
    Jun 26, 2018
    Childersburg, Al
    Thanks for the info...
  8. xvz12
    xvz12 Well-Known Member
    730
    364
    Apr 6, 2017
    New Plymouth, ID
    Another thing to measure is the clearance between the tire & the cross members which are both in front & behind the tire...on our Cape Cod (which also has 10" wheels), this clearance was MUCH less than the clearance needed between the top of the tire & the fender well. On ours, it was close enough, I ended up staying with the stock tire size whether I liked it or not. An axle flip is pretty much out of the question for us, as the wife is mobility impaired, & and can barely make the step up now...
  9. Raycfe
    14,245
    1,017
    Your Coleman came with 20.5 X 8X10 tires(big tire,little fat rim) and 13 tire would be about 24 inches in diameter.
