Tire question.
Discussion in 'Tires / Brakes / Bearings / Axles' started by Ray krueger, May 21, 2019.
  1. Ray krueger
    Ray krueger New Member
    May 21, 2019
    I own a 1996 Jayco 1206 with a 10 inch. 20.5x8 with 4 bolt pattern Tire setup I have seen these tires at Menards That I have attached with these also work for the trailer thanks for any help
  2. Sjm9911
    3,392
    1,591
    https://www.etrailer.com/faq-wheel-bolt-pattern.aspx
    Info on bolt patterns
    Next thing to figure out is weight rating, so you need to know that. And speed rating. Additionally there are bias and radial tires. So get the numbers from your tires now, then check to see if the weight rating is correct. Some dont put the correct tires on the pup. Good luck , its more complex then it seems at first but after you learn it its easy.
  3. Shaman1
    Shaman1 Well-Known Member
    1,940
    396
    May 13, 2011
    Oklahoma City, Oklahoma
    I can't read the speed or weight rating in that picture. I try to go up at least 1 weight rating over the original and keep a speed rating for the interstate.
    theseus and Sjm9911 like this.
  4. Ray krueger
    May 21, 2019
    OK thanks yeah I’ll have to take a better picture I don’t recall seeing a speed rating on these but I had to get back to work so I didn’t of course take a good photo
  5. WrkrBee
    WrkrBee Well-Known Member
    1,752
    636
    I'm not a punctuation police, but what is your tire question?
  6. Ray krueger
    May 21, 2019
    I thought I put it up there I’m looking to see if these tires would be sufficient replacement for the ones I have on my trailer now when I get home from work I will look at my spare tire and compare this tire thing is all new to me
  7. WrkrBee
    1,752
    636
    Well, I may be after all. No where is there a question.
  8. theseus
    theseus Centerville, OH
    2,775
    375
    Feb 6, 2007
    Centerville, OH
    Those tires might work if you have a four bolt pattern. However I have found that the big box stores usually carry tires that are meant for lightweight utility trailers not for campers. You probably want c load rated tires, and a speed rating of at least 65 mph.
    Check out etrailer.com.
