Towing with a 2018 Odyssey
Discussion in 'Tow Vehicles, Hitch & Towing' started by ryangates13, Jul 20, 2018.
  1. ryangates13
    ryangates13 Member
    35
    Jan 26, 2017
    I'm going to be towing my pup with my van. I'm doing research on how to set up the van. I'm going to put in a brake controller and I'm trying to figure or what to do to help with the sag caused by the weight. I'm a newbie to all this so any suggestions would be great. Thanks!
  2. Rusty2192
    Rusty2192 Active Member
    702
    209
    Jul 30, 2014
    Kentucky
    How big is the pup and what is the tongue weight? If it’s at the higher end, you may need to explore weight distributing hitches (WDH).
    Otherwise, airbags or a rubber spring like a Timbren do a great job at stiffening up the rear suspension. I added some Airlift 1000s to our Sienna and they help a ton. They were really easy to install on it, though the process may be different on your Odyssey.
  3. ny_rocking_chairs
    ny_rocking_chairs Active Member
    266
    40
    Jul 17, 2016
    Webster, NY
    We tow with a 2014 Ody, have installed the Timbren springs and a transmission cooler.
  4. ryangates13
    ryangates13 Member
    35
    Jan 26, 2017
    It weighs about 1500 dry and hitch weight is 175. All in all pretty light.
  5. MNTCamper
    MNTCamper Active Member
    688
    99
    Jun 14, 2014
    Your van is so new that I don't see anything in regards to what shocks fit, but for sure you could add air bags. I have used those on a previous Ody. They work well and you can adjust them. About $80 and then installation (can DIY). Tranny cooler is a very good idea (I would call it a must). Other than that, sounds like you are ready to go.
  6. Spaceace5150
    Spaceace5150 Member
    108
    17
    Oct 1, 2014
    Do you have the factory tow package? I added a non-Honda hitch to my 2011 Odyssey and that is the only reason it sits a little low. If I'm loaded down it scraps when going into my driveway. Thinking about adding airlifts. If you have the factory hitch, it sits higher and may not be an issue.
    If you do not have a transmission cooler (the factory package includes a small one), have one added.
    Your pop up is light like mine (Rockwood 1640), so you should be in good shape!
  7. Orchid
    Orchid Sharp Shootin' Grandma
    4,748
    1,240
    May 8, 2011
    Florida by way of WV and MD
    My Odyssey owners manual specifically says never to use WDH. Really should never need one on a pup anyway.
    We put rear air bags on ours, it was easy DIY. Also added a transmission cooler.
