Trailer tires sitting in one spot all winter
Discussion in 'Tires / Brakes / Bearings / Axles' started by Indianrock, May 24, 2019.
  1. Indianrock
    Indianrock Member
    113
    Feb 25, 2012
    I'm sure this has been asked, but I'm wondering if I should move my trailer a few times during the winter, or probably best, how to economically lift the trailer and tires for the winter? If I don't want to spend for "trailer legs," can I safely jack it up and correctly position some good jack stands?
    http://tinyurl.com/y53vn7co
  2. xxxapache
    2,740
    759
    Just make sure they are fully aired up and don't worry about them. Covers are a good investment, IMO.
  3. PopUpSteve
    PopUpSteve Administrator
    18,555
    1,403
    Dec 22, 2002
    Malvern, PA
    Yes, by all means move them many times over the Winter and all year long BY GOING CAMPING! [LOL][LOL][LOL][LOL]
  4. bheff
    bheff Active Member
    399
    133
    Feb 24, 2011
    NW Arkansas
    If you are really worried about it, go to Walmart or Harbor freight and buy 2 $8 Jack stands. Place them under the axle and call it a day.
    Indianrock likes this.
  5. MNTCamper
    MNTCamper Active Member
    778
    139
    Jun 14, 2014
    It is not an issue to worry about. The tires remain round. Just make sure you air them up properly before storage.
  6. Indianrock
    Indianrock Member
    113
    Feb 25, 2012
  7. xxxapache
    2,740
    759
    If you really want to try and protect your tires, take them off and store them indoors.
  8. Snow
    9,827
    845
    Park the trailer wheels on some 2x10, air them up and cover them..
    tenttrailer likes this.
  9. Indianrock
    Indianrock Member
    113
    Feb 25, 2012
    I could do that after putting it up on jack stands. One typical 3-ton jackstand under the frame ( not axle ) behind each wheel along with a support under the tongue ought to be adequate for a 2800 pound trailer
  10. Snow
    9,827
    845
    Another idea, depending on how old the tires are.. Buy a new set of tires with rims for summer use and swap them out with the current set in the fall and use the older tires as "winter storage" tires.. I did that for 3 years with our pup..
  11. Wakita46
    Wakita46 Active Member
    218
    48
    Mar 15, 2013
    I think tires used to be more likely to take a set in the old days. I have stored mine every winter for 6 months at a time without any problems. I did buy new tires after they got 5 years old. I have 35,800 miles on the camper and have not had any problems with the tires.
  12. WrkrBee
    WrkrBee Well-Known Member
    1,909
    714
    I had a friend that jacked up his camper for the winter and deflated the tires to a low pressure. Come spring he aired them up for the first trip and had two bad ones. Go figure. I just leave inflated and covered.
  13. Indianrock
    Indianrock Member
    113
    Feb 25, 2012
    Interesting but hard to draw a conclusion since we don't know if those tires were already borderline.
    http://rvlife.com/trailer-legs-rv-tire-storage/
  14. Indianrock
    Indianrock Member
    113
    Feb 25, 2012
    On the RVLife web site the creator of Trailer Legs made a comment that was interesting:
    "I have yet to figure out how to safely lift my trailer by its frame."
    Not sure what he meant about that although on a gravel parking pad like mine I can see some issues. I just jacked mine up using a 20-ton bottle jack with 2x4 block on top to lift the wheel by the frame ( jack to the rear of the single axle. ). I was able to put in a jack stand under the frame between the bottle jack and the tire but you do have to be careful about the jack remaining level.
    TrailerLegs utilizes a 4″ wide axle cradle which positions next to your trailers spring purch. Most axle manufacturers use a 1 7/8″ wide spring and purch. TrailerLegs applies less force to the axle tube than the spring and purch do.
    If you have ever jacked your trailer up from the axle, you will have probably noticed that the jack and jackstand take up quite a bit of area along the surface of the axle. Also, the width of the surface supported by a jack or jackstand, usually is less than an inch wide. These conditions are why the axle manufacturers refer to using the frame as a jacking point.
  15. Dont slow down
    Dont slow down New Member
    Aug 13, 2018
    I’m curious as to why everyone says don’t put the jack stand under the axle? My jack stand has a curved perch and cradles the axle just right. The weight is still being held by the springs, just the same as if it was sitting on the ground. I don’t see anything wrong with this method. It’s a steel tube, not a plastic straw.
  16. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    If storing on grass or dirt? I would put it to rest on a 2x8. Wet dirt can leach out the oils out of tires.
