1. Beekeeper1
    Beekeeper1 New Member
    17
    Feb 12, 2018
    Whitman Creek, WV
    I have a 2004 Palimino 280 Pup. Trying to get it ready to take out later this month. Just discovered that the fresh water tank leaks. Not going to try any repairs at this time, but was wondering if anyone could tell me how hard it will be to remove the tank for repairs.
  2. Sjm9911
    2,145
    837
    Are you sure its not leaking from a plug, overflow or valve?
  3. Raycfe
    13,959
    943
    Should be too hard to remove. When you are going to start the job lub up and mounting bolts a day or two ahead of time. Fresh water usually don't leak. Check the hoses and drains. Some times a tank can be repaired without removing.
