Water Pressure Regulator lubricant
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by kcsa75, Jul 19, 2018.
  1. kcsa75
    kcsa75 Well-Known Member
    1,819
    695
    Sep 9, 2013
    Kansas City
    I have a Valterra lead-free water pressure regulator.
    There is no visible corrosion, but it's a couple years old and is getting harder to turn when attaching to the hose bib at the campground. I leave it attached to the fresh water hose in when not in use, but always drain the hose before putting it away.
    Is there lubricant that can be used on brass? [:)C]
  2. Sjm9911
    1,992
    794
    Use some pipe thread, it will turn easier. I see this with the hose nozzles etc, stuff isn't as good as it used to be .
  3. nineoaks2004
    5,693
    2,011
    Graceville, Florida
    Mine is at least 15-20 years old, I have never had a problem with it getting stiff, I also carry a spare just in case. Maybe mine gives no trouble because it was made in the U.S. and everyone knows about the Chinese made items.
  4. Sjm9911
    1,992
    794
    I have an old one I will keep, but I don't expect the new one I got to last a long time. Nothing is made as it was. Everything is disposable now a days.
  5. nineoaks2004
    5,693
    2,011
    Graceville, Florida
    Use the old one and keep the new one for a spare, the older one is probably a lot more dependable, My neighbor (long ago) refused to use a pressure regulator, first time hooked the water in we spent the whole day of fishing repairing water lines :) the water pressure in the CG was 100 + psi. (private owned CG)
  6. mstrbill
    mstrbill Active Member
    647
    135
    Mar 17, 2013
    Austin , Texas
    try some silicone grease; waterproof and non-toxic.
  7. Fless
    Fless Active Member
    Plumber's grease. But first soak it in vinegar at least overnight to dissolve the scale that has possibly built up.
    _
    Raycfe likes this.
  8. giadiep
    giadiep Active Member
    335
    131
    Sep 5, 2015
    Syracuse, NY
    Use Vaseline. Safe, non-toxic.
