Water pump not sealing?
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by mountain mike, Jul 28, 2018.
  1. mountain mike
    mountain mike New Member
    Jul 25, 2017
    Been chasing a leak for a little bit. I disconnected the inlet from the water pump, plugged it with my finger, ran the pump and was unable to get the pump to stop running. Look off the outlet and plugged it with my finger and also could not get the pump to turn off. Could this mean my pump is not sealing and is causing the leak? It is leaking sometimes around that area but not all the time and I can’t figure out where the water is dripping from when it does leak.
  2. joet
    3,562
    516
    By removing the pump intake line, the pump will run because there isn't any water to build pressure to shut it off. If the pump will not shut off with the outlet plugged and there is water on the inlet side,,, pump is bad
  3. mountain mike
    Jul 25, 2017
    ^^thanks. I also just hooked up to city water and everything works great with no leaks. Off to replace the pump. :)
