Weight distribution hitch: yes or no?
Discussion in 'A-Frame PopUps' started by Yacoma99, Mar 29, 2019.
  1. Yacoma99
    Yacoma99 Member
    36
    23
    Mar 25, 2019
    The dealer I bought my ntu Ranger 12 from recommended a weight distribution hitch. The Ranger 12 is pretty light and my truck is rated to tow up to 6400lbs. What are y’all’s thoughts?
    Thanks
  2. theseus
    theseus Centerville, OH
    2,799
    390
    Feb 6, 2007
    Centerville, OH
    What is your tow vehicle? That would help us give a better answer.
  3. Yacoma99
    Yacoma99 Member
    36
    23
    Mar 25, 2019
    My tv is a 2017 Toyota Tacoma 4x4 Sport, double-cab, long bed with the factory tow package.
  4. WrkrBee
    WrkrBee Well-Known Member
    1,914
    715
    We drag our Aliner Scout around, with an older F150, without a weight distribution hitch. Tongue weight, weighed it 2 weeks ago, is 160 lbs. loaded trip ready. Barely know it's back there.
  5. NMroamer
    NMroamer Active Member
    448
    201
    Apr 21, 2016
    Albuquerque NM
    The dealer is trying to make a sale. Rule of thumb is anything above 3000 lbs should have a WHD hitch. My trailer is just under the 3000 lbs and I put one on for piece of mine.
    If you decide you need one I have an extra that you can have a lot cheaper than the dealer would charge.
    Easy to install yourself.
    Rik Peery and Sjm9911 like this.
  6. durhamcamper
    durhamcamper Active Member
    713
    157
    Apr 21, 2010
    Pickering, Ontario
    I really doubt it's necessary. That is a really light trailer
    PointyCamper likes this.
  7. nineoaks2004
    6,819
    2,739
    Graceville, Florida
    I had a friend give me a wd hitch, I have never used it but I do use an anti sway bar, mostly to offset semi's passing or meeting me, I do pull a small TT which is higher that a pup, but I also used one when I had a pup.
  8. generok
    generok Well-Known Member
    2,396
    545
    Feb 7, 2013
    Anchorage, AK
    It's really more of a "how does it tow" function. While you probably don't NEED it, if it sways or you get a lot of rear sag, a WDH with sway control can help with that. So can other things, but if it tows nice without, if it were me, I'd skip it. I towed my PUP for 5 years without a WDH and never even felt it back there.
    neighbormike likes this.
  9. Strawhouse
    Strawhouse Well-Known Member
    1,233
    370
    Oct 4, 2015
    Muskoka, Ontario
    I’ve towed my 2014 Aliner 15 Ranger for two seasons without any additional towing accessories. It tows beautifully! My Ford Escape is rated to tow approx 4600lbs.
  10. gladecreekwy
    545
    541
    Sep 25, 2016
    Waste of $$$
    Rik Peery likes this.
  11. giadiep
    giadiep Active Member
    385
    159
    Sep 5, 2015
    Syracuse, NY
    When you put weight on the back of your tow vehicle, it can take weight off of the front of your vehicle. Depending on how much weight you put on and how heavy or light your tow vehicle is, you may feel that you have less control of the steering. That may be another reason to use a wdh. Just because a vehicle is rated to tow a certain weight or a certain tongue weight does not mean it can cheat physics. Ideally, you distribute that weight evenly across both axles. Now, there are degrees of reason at play. If you’re towing a 2000 lb pup with a full size truck, it probably isn’t enough tongue weight to have much effect on your steering ability.
  12. McCampers
    McCampers Member
    44
    25
    Oct 16, 2016
    You should not need a weight distribution set up if your trailer is properly balanced and you have the right height drop hitch on the truck. Hook up your trailer to your truck then park on level ground. Measure the frame height in the front and the back of the trailer. Generally the front should be around 2 inches lower than the back for proper tongue weight. If it is not buy a hitch that raises or lowers the ball to that height. A lot of trailer sway is caused by too little weight at the hitch. If your rig is under 3000 pounds you should not need a weight distribution system. A balanced load at the right level should not have any sway. If your trailer is balanced and at the right hitch height and still sways you have a problem that needs to be fixed, usually a problem with a bent axle or the axle alignment. Either of these problems will leave you broke down soon enough and usually at the worst of places. Good luck and enjoy.
    tzmartin likes this.
  13. Sjm9911
    3,642
    1,786
    I tow my westlake with a full size truck, its about 3500 lbs loaded as a guess. I dont even know its there. As others stated, tow it first. I would say you dont need it.
  14. Yacoma99
    Yacoma99 Member
    36
    23
    Mar 25, 2019
    Thanks for all the replies. I am definitely going to tow it on a few trips before I buy a wdh.
    shuang2, theseus and PointyCamper like this.
  15. jadmt
    jadmt Member
    37
    Mar 26, 2019
    I just bought a Ranger 12 a few days ago and towed it from Pasco Wa to Boise and then from Boise to Missoula so plenty of up and down and drove pretty much the speed limit and no issues at all and I was towing with a jeep wrangler. I have dual lp tanks and battery and my tongue weight is still pretty light.
  16. nhlakes
    nhlakes Well-Known Member
    643
    317
    Oct 15, 2011
    DE and NH
    If you were to install a WDH setup the first thing you would do is measure the height of your Tacoma wheel wells before and after the trailer is on the hitch. The Tacoma is a decent little tow vehicle. I seriously doubt the rear of the Tacoma is sinking low enough with the Aliner attached to require a WDH to redistribute the load. If the trailer is angled to much up/down, just get a drop-down ball mount of the appropriate height to lower or raise the ball.
  17. Yacoma99
    Yacoma99 Member
    36
    23
    Mar 25, 2019
    As a follow up on the thread I started, I picked up my Aliner last week. After a 4 hour tow over various road conditions, I have determined there is no need for a wdh. I appreciate all of the input.
    William Freeman and gladecreekwy like this.
