What did you do to your TV this month
Discussion in 'Tow Vehicles, Hitch & Towing' started by Yak, Apr 2, 2016.
  1. Yak
    Yak Well-Known Member
    1,204
    78
    Apr 18, 2009
    I bought my 05 Dakota new and it's time to do some work. Last week I mounted a set of 31" Hankook ATMs, a tad taller and a bit more aggressive tread. This week, I repaired the rust in the LF inner fender, cut out the bad stuff and welded a panel in. I also replaced the rear spring shackles that were looking a bit nasty. Next, I'm going to tackle the rust on the rear wheel lips. I have 68k on it and have done very little in the 10+ years I've owned it.
  2. yetavon
    3,286
    168
    Mar 11, 2010
    Western NC
    Well last month we replaced it, 7 years newer and 22K miles less. This month....extendable power tow mirrors will be here Wednesday....
  3. kitphantom
    11,207
    511
    We bought a new-to-us TV at the end of February, and took it for the first trip Easter week. We had a tonneau cover and running boards added before the trip. We're glad we did not spring for the divider that's available, using several totes of different sizes kept it organized.
    I finally contacted the dealership about the problem floral smell in it. The "customer experience manager" agrees (by email) that it should not have happened, and that they "will take care of it". We'll see what that means.
    I'm still working on solutions for the lack of door pockets, place to put a trash bag and the drier's seat that is not shaped well for either of us. Not the first vehicle that I've had to use a cushion or something to compensate for my short legs.
  4. xxxapache
    2,563
    622
    New carb, air filter, and changed differential oil, which I figured it needed after 39 years. I also bought a set of spare belts and hoses to carry behind the seat....No need to replace the originals before they need it....lol.
    DR Stitch H.D likes this.
  5. tenttrailer
    2,928
    201
    Jul 18, 2013
    Thornville, OH
    Just got some 12v fans for the fridge. 2 for the outside vent and 2 for the inside coil and air circulation. This sould keep it in the mid 30's when the outside in high 90's
    Started stacking up on mods this winter. New digital thermostat, New GFI outlet to be added out side so I can tap off the Air Con line and run an electric heater via short extension cord. Need to do some re- chalking.
    Planning first camping trip 4/21 for 3 days hope to have mods installed for the trip.
  6. Yak
    1,204
    78
    Apr 18, 2009
    TV!!!???
  7. vagov
    vagov Well-Known Member
    3,910
    170
    Aug 13, 2012
    Pittsburgh, Pa
    Replaced battery, changed oil, new air filter, new wiper blades, new front. Crankcase seal, and flushed. Transmission. Fluid
  8. bud121156
    bud121156 Western North Carolina
    4,631
    24
    Apr 15, 2007
    North Carolina
    Washed the pollen off of it.
  9. Rusty2192
    Rusty2192 Active Member
    682
    197
    Jul 30, 2014
    Kentucky
    I figured out why my 7 way trailer plug wasn't working correctly. It looks like a previous owner hit something to pinch the wires which let water in. The wire for the running lights was the worst and had corroded completely through. I tried soldering in a wire at the break, but the remaining bit was too far gone. Looks like I'll need to replace the plug since the wire broke right at it with no way to splice anything in.
  10. PointyCamper
    PointyCamper Active Member
    482
    86
    Nov 25, 2015
    Washed it yesterday. It needed it. Then we closed it up because of the high winds forcast, which we did have last night. Today we continue packing!! Beach-bound
    [ALPU] [TV]
  11. tcanthonyii
    tcanthonyii Member
    910
    Jun 29, 2010
    Well last month I fixed the spare tire carrier. The winch was rusted up solid and would let the tire down. Also added a tail gate extender. The switch from a 6.5 bed to a 5.8 bed with the crew cab meant a lot less cargo space. Picked it up for 75 bucks in Topeka on my way home from Tulsa.
  12. f5moab
    1,423
    463
    May 7, 2013
    Somewhere in Idaho
    Brushed and vacuumed out a bushel of white Malamute undercoat fur, from the back seat, after a trip to Moab and back. [:D] It's that time of the year. [;)]
  13. Rusty2192
    682
    197
    Jul 30, 2014
    Kentucky
    I replaced the 7-way plug today. I was able to reuse the factory bracket and just drill new mounting holes. Finished in about 15 minutes.
  14. Haybale
    2,453
    252
    Aug 22, 2013
    San Diego via MN
    Added oil as I set the empty jug on my parts car with a 50k less mile and much less oil burning motor....
  15. HiFiDave
    HiFiDave Singin round the campfire
    1,069
    Feb 1, 2012
  16. niagarafam
    niagarafam Active Member
    2,158
    Jan 25, 2014
    Gave her a "warsh" as my pa would say. Rotated and balanced the Goodyear Wranglers. They have 52k on them. I priced new Michelins. They will go on the list and likely on the truck this fall. I'm gonna try to squeeze another 8k out of the Wranglers. They look okay for trip to NM in July, but I am starting to keep a careful eye on them.
    Made my June list: differential fluid, tranny fluid and filter, dreaded Hemi tune up (appreciate suggestions DIY), cabin air filter kit install, suspension assists - then off we go to Santa Fe!
  17. yetavon
    3,286
    168
    Mar 11, 2010
    Western NC
    And a Kayak rack
  18. niagarafam
    2,158
    Jan 25, 2014
    Cool! I like the barn!
  19. kitphantom
    11,207
    511
    The dealer had someone remove the overwhelming scent bomb stink that was still evident almost 6 weeks after purchase. So far, it is much better, though I think there's still a bit. Hoping it is down to a level that won't give me a headache after traveling in the truck for a few hours, or still be too strong for my more asthmatic friends to ride in it. We still leaving the windows ajar when it's parked, wide open as we can.
    I'm researching seat covers, I'd like to find one that is comfortable and will hold a foam seat cushion, filling in the well of the bucket, in place. I like the look of the Carhart, but we haven't decided to buy them yet.
    I need to make a seat cushion so that the driver's seat works for both of us. On this Colorado, the driver's seat slopes too much to the rear, and there is no adjustment for that. The "bolster" edge of the seat is also not comfortable for either of us. When the seat is set where I really want it, the bolster is annoying and actually makes it difficult to set my heel on the floor.
  20. Haybale
    2,453
    252
    Aug 22, 2013
    San Diego via MN
    I added oil again....
