What do you tow with?
Discussion in 'PopOut (Hybrids)' started by Rinstah, Sep 4, 2017.
  1. CrystalCoastCamper
    CrystalCoastCamper Stay strong and Camp on!!
    46
    Jun 16, 2015
    Newport, NC
    Our TV is a 2014 F150 XLT with the 3.5L V6. Plenty of towing ability plus room for DAYS with the crew cab. One thing to think about is does this trailer have brakes? Our truck already was set up for towing with the factory brake controller and transmission oil cooler and it pulls our 3000# a-frame like it's not evn back there. I don't believe a lot, if any, midsize SUV's are already rigged up for trailers with brakes but you can find aftermarket controllers pretty easy though.
  2. Halford
    Halford Well-Known Member
    2,527
    119
    Sep 28, 2011
    Santa Clarita, California
    My Explorer has the similar 3.5L V6 engine that tows my 3500# like its nothing back there.
  3. Fless
    Fless Active Member
    I tow with a truck-based SUV, a Tahoe with a 5.3L gas engine. Pulls my Cheyenne (~3K lb. gross) with ease, even up high mountain passes.
  4. mdcamping
    mdcamping New Member
    21
    Mar 25, 2015
    I tow with my 07 Toyota Tacoma,Double Cab, Max Towing 6,500lbs. I have a 2011 Jayco X20 E, 3700 Dry weight Hybrid "Towing with 165K on my Tacoma"
    Mike
    NMroamer likes this.
  5. Daisy on my toe
    Daisy on my toe Member
    59
    18
    Jun 21, 2017
    Chicago area
    We have a 1/4 ton Chevy Silverado it has a factory tow package isn't necessary towing our little pup but does make me more comfortable.
  6. bikendan
    bikendan Member
    441
    Feb 26, 2012
    i thought the Silverado was a 1/2 ton[;)]
  7. f5moab
    1,014
    230
    May 7, 2013
    Eastern Idaho
    Never heard of a Silverado being rated for 1/4 ton. Those old tonnage ratings of 1/2 ton (1500), 3/4 ton (2500), 1 ton (3500) are carryovers from the 50s. Today a 1500 can carry more than Actually, a Silverado can be a 1/2, 3/4 or 1 ton; however, it sure is not a 1/4 ton. (However, those old tonnage ratings are left over from the 50s and a 1500/150 series can easily carry more than a 1000 pounds and the others have a greater payload than the old rating.)
    Fbird likes this.
  8. Daisy on my toe
    59
    18
    Jun 21, 2017
    Chicago area
    Yes, 1/2 ton you are correct. My mistake. It is my husband's vehicles I don't know all the specs. [:I]
  9. southern_gs
    southern_gs New Member
    Mar 30, 2015
    Atlanta, GA
    Currently pulling 2015 Shamrock 23SS with a 2002 Suburban 5.3....215K miles on the odometer! Just went out this weekend and it pulled like a champ. Mind you, we stay fairly close 1-2 hours from Atlanta, southward. Not sure how I would feel trying to pull over the mountains with this rig. I can hold 55-60 most any flat road...occasionally downshifting but not going over 3500 RPM. Big hills are a different story. Worst yet was a long, steady climb and I dropped to 50 MPH, pedal down, running 4K RPM. Get a good WD hitch + sway control. We added Air Lift air bags (under $100) to help out with any droop in the back. Makes things nice and stable. If I were pulling over mountains or long hauls, I would want a 2500 series Suburban or truck.
  10. Halford
    2,527
    119
    Sep 28, 2011
    You may not need to get 2500 Suburban. I believe the 1500 is enough to tow 6400 lbs max weight. The max tow weight for the Sub is 8000 lbs. Unless the Sub is acting its age, then get the new 1500 Sub if you wish. the 2500 would be better but see the new technology today may allow the 1500 do a good job towing.
    southern_gs likes this.
