What is a good brand of roof mounted AC unit?
Discussion in 'Heating / Cooling Systems' started by ham fam, Jul 6, 2018.
  1. ham fam
    ham fam Member
    38
    Jul 20, 2016
    Kaukauna WI
    We have a 2004 Rockwood 2290. It has the roof bracing, and the manufacturer says the roof can carry 200 lbs. From the forums I understand that I need 12000 BTU. I think it will add some nice resale value, so what is a good brand?
  2. JPBar
    JPBar Well-Known Member
    1,865
    574
    Sep 22, 2016
    Texas
    I have a Coleman Mach 3 (13,500 BTU) no complaints for the last 3 years, works well here in the Texas heat. Manufacture says it weighs 90 lbs.
    Good luck I am sure others will chime in here.
  3. xxxapache
    2,740
    759
    My TT is a 1995. It still has its original Dometic Penguin.
    JPBar likes this.
  4. Sneezer
    1,438
    469
    I have a 99 with the original Dometic. Still runs fine but on a pup it probably didn't get as much use as a TT.
    I would get a 13.5k BTU at minimum. 15k was usually the optional size.
