What kind of oil/grease for a jack?
Discussion in 'Tires / Brakes / Bearings / Axles' started by mpking, Sep 5, 2018.
  1. mpking
    mpking Well-Known Member
    1,087
    196
    Jun 17, 2014
    Raynham, MA
    I want to lubricate the tongue jack.
    It got a small hole (1/8 to if an inch?) at the top marked oil.
    What do you guys recommend?
    I don't have anything on hand, so I have to go and buy it.
    White lithium?
  2. Raycfe
    14,120
    983
    Motor oil ....3 and oil ......etc. You want it thin enough to travel down the inside of the jack.
    xxxapache likes this.
  3. xxxapache
    2,620
    662
    I just use my old school pump oil can with motor oil in it.
    If I had to buy something, I would buy Rem Oil gun oil in an aerosol can and use the applicator tube to spray it in.
    jnc likes this.
  4. Sjm9911
    2,638
    1,048
    I would go with motor oil. The 3 and one drys out way to fast.
  5. mpking
    1,087
    196
    Jun 17, 2014
    Raynham, MA
  6. Sjm9911
    2,638
    1,048
    Just a sugestion, if it's a hole marked oil, I don't think the heaver grease will get on the entire thing. Grease is good for like gears etc, when you need it to stick and stay put. Or when you need it to keep out the elements.
  7. xxxapache
    2,620
    662
    The hole says "oil", I would use oil.
  8. MNTCamper
    MNTCamper Active Member
    719
    102
    Jun 14, 2014
    Any motor oil, 5WX, 10WX will work fine. If you don't have a small oiling can, I would encourage you to get one. It has a huge number of uses for this application and many others.
