Wheel Bearing Hub "Grime"
Discussion in 'Tires / Brakes / Bearings / Axles' started by WhiskeyTakesTheWheel, Jul 29, 2018.
  1. WhiskeyTakesTheWheel
    WhiskeyTakesTheWheel New Member
    May 14, 2018
    First pop up and its fairly new - 2015 mac. The old owner didn't know what repacking bearings were so I figure'd it was a good idea to knock that out before any trips, but the housing has some very hard "grime" buildup that I wasn't expecting. Is this normal & not an issue with enough grease? If not, then is this something to try and clean off with a wire brush or are these hubs shot?
    Edit: I sprayed purple power on it and tried to scrub off with a general sponge but nothing was coming off. If I scrape with my nail, this also doesn't remove any.
    https://imgur.com/a/1owX33o
  2. phoodieman
    phoodieman Active Member
    766
    72
    May 18, 2009
    Hutto, Texas
    The spindle rides in the bearing race. I don't see any problems with what you have in the pictures.
    Phoodieman
    kcsa75 likes this.
  3. WhiskeyTakesTheWheel
    May 14, 2018
    So its normal to get that buildup where the threads sit in the middle?
  4. phoodieman
    766
    72
    May 18, 2009
    Hutto, Texas
    Unless this is a set up I'm not used to, those aren't threads. Just lathe turn artifacts from the secondary machining on the cast hub. It's hard to tell from the pics, but it looks like you still have the races pressed in. The axle spindle wouldn't come near to contacting any of those areas, and should be full of grease after you re pack and reinstall. In fact the set up looks in excellent condition. Just properly repack, grease and tighten it all up and you should be in great shape.
    Phoodieman
  5. joet
    3,992
    671
    Repack them. they will be fine. Machining marks
    xxxapache likes this.
  6. Raycfe
    14,240
    1,017
    ditto^^^^^^^
  7. WhiskeyTakesTheWheel
    May 14, 2018
    thank you
