Wheel Bearing Seals
Discussion in 'Tires / Brakes / Bearings / Axles' started by opie232, Apr 20, 2016.
  1. opie232
    opie232 Member
    283
    Mar 1, 2013
    Dumb question,
    I have never serviced the bearings opn my PUP, Yes I know thats bad but I did have new bearings and seals installed with a complete brake system when I bought it. My question is where can I find the correct size seals for my unit? I do not see them in the owners manual. Can I get buy with re using the existing seals if they are not worn or cracked. Just bought a new set of shoes for her since the old tires are cracked. Figured it was a perfect time to repack the bearings as well.
    It is a 97 Jayco 1207KB.
    Help is always appreciated.
    Thanks in advance.
  2. Halford
    Halford Well-Known Member
    3,557
    555
    Sep 28, 2011
    Santa Clarita, California
    depends on your axle.. 10" Dexter? snap picture of the brake when you take off the drum and go to a trailer shop. they should have everything there. show them the picture of the drum and the brake system then they will know which seal and bearings you need.
    On the second thought, I am not sure there's brakes in there. snap pic of front of drum, then show the trailer shop what you have.
  3. opie232
    opie232 Member
    283
    Mar 1, 2013
    Will do. Thanks
  4. SteveP
    SteveP Well-Known Member
    1,318
    318
    Take the old seal to your local auto parts store. They can match the part number on the seal. They may not have it in stock but they can order it. If you need to order get 4 and save 2 for possible emergency.
  5. fix_it
    fix_it Member
    594
    Aug 29, 2010
    1207 kb has a #9 dexter Axle with 7" hydraulic brakes. It's a 2400 lb Axle with straight spindles. It's a common seal but I don't have the number. Maybe this info will help track it down.
  6. sgip2000
    sgip2000 Member
    536
    Jun 16, 2010
    Hillsboro, OR
    NAPA likely has them. Just take hub in with you.
  7. Dubbya
    6,128
    51
    Aug 2, 2011
    Steinbach, MB
    Yes, if you have standard hubs, the seals aren't leaking and appear to be in good condition, you can reuse the old seal(s).
    If you're going to replace bearings anyway, spend $13-$25 a wheel and get a kit with the seals, cotter pin, grease cap, bearings and races. Any commercial trailer shop or RV dealer will have them.
    If you have brakes with bearing buddies or ezlube axles, you should replace the grease seals.
  8. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
    If the bearings and races are in good condition, you don't need to replace them, just the seal.
  9. silvermickey2002
    4,588
    405
    Sep 11, 2008
    Morris County, NJ
    Since bearing seals are not that expensive I would also recommend replacing them whenever you pull the bearing out.
