Wheel Well Repair
Discussion in 'Tires / Brakes / Bearings / Axles' started by Bigantlers, May 17, 2019.
  1. Bigantlers
    Bigantlers Member
    62
    Jun 6, 2018
    Toledo, OH
    When I was bringing the PUP home last year I had a tire blow and put a hole in the plastic wheel well. I put packing tap on it which worked well but is peeling off. I was going to use Flex Seal tape to sandwich the hole from each side but saw some posts discouraging its use.
    So any suggestions of how to patch a plastic hole without replacing the well?
    It has to hold up to the elements of course. I was wondering if I could lay some on it using tap as a mold but I'm thinking it won't be thick enough or rigid.
  2. McFlyfi
    McFlyfi Active Member
    334
    129
    Aug 1, 2014
    Thousand Oaks CA
    I've thought about this in the past. I haven't had a damaged wheel well, but I always thought that I would patch it using some thin aluminum, glued and riveted to the wheel well.
    I doubt the Flex Tape would last very long.
  3. eoleson1
    eoleson1 Well-Known Member
    1,960
    480
    Jul 5, 2011
    Macomb County Michigan
    How big is the hole?
  4. Anthony Hitchings
    215
    74
    Mar 2, 2019
    I need to do this too - in my case, from tire rubbing
  5. WrkrBee
    WrkrBee Well-Known Member
    1,752
    636
    Ours wells are just thick flashing, or thin metal. A piece of thick flashing, with solid rivets, and sealant should fix about any size hole, even around corners. Should work on plastic, also.
  6. Overland
    Overland Active Member
    200
    118
    May 1, 2013
    Bristol, Pa
    I only know my particular camper, so excuse me if i'm mistaken. But aren't these plastic wheel wells like mine where they screw to the floor and wall with a flange?
    New well, screws, and silicone sealant and done? I'm sure i'm missing something.. ;)
  7. xxxapache
    2,715
    740
    I had a 1 x 3 or so hole in mine. I used JB steel stick or similar to cover it....I just pushed it over the hole.
  8. Dingit
    Dingit Well-Known Member
    716
    300
    Mar 8, 2017
    I had a little bit of wear through the plastic on mine from the tire being too close (I hope the axle flip fixed that issue). I couldn't think of anything brilliant so I slapped some eternabond tape on it. It's in the sink cabinet so it's easy to check up on. So far so good. It's been towed through some nice PNW rainstorms.
    But this was just a thin patch with a few pinholes. A bigger hole might require some effort!
  9. Bigantlers
    Bigantlers Member
    62
    Jun 6, 2018
    Toledo, OH
    Here's what it looks like:
    Its about 4" across by 1". Eternabond may be an option. maybe I can fill the void with epoxy sandwiched in between two pieces.
  10. WrkrBee
    1,752
    636
    Is that wood or insulation behind the hole?
  11. Bigantlers
    Bigantlers Member
    62
    Jun 6, 2018
    Toledo, OH
    No that is tape and beyond that is the storage space the well sits in. Up to this point I put packing tape on the well and then put a layer over the hole from inside the camper.
  12. Bigantlers
    Bigantlers Member
    62
    Jun 6, 2018
    Toledo, OH
    @Overland : I plan on doing work to the lower half next year so maybe I'll just through new wells in. Its pretty much like you described.
    @xxxapache : JB Steel Stick? I'll have to look into that to get me through the season.
  13. xxxapache
    2,715
    740
    @xxxapache : JB Steel Stick? I'll have to look into that to get me through the season.[/QUOTE]
    It's a two part epoxy in a stick like cookie dough. Just knead until the parts mix and make your repair. There are other brands like Quik Steel. I have used both of those with good results.
  14. WrkrBee
    1,752
    636
    I would probably work the ends of the worn area out a little to where it was thicker material, maybe with a small screwdriver. Cut thick flashing an inch wider than the finished widened slot. Make the patch long enough to go an inch above the crack in the wheel well and long enough to fold back under the wheel well lip. Notch the bottom corners just wide enough to push through the slot from the inside. Coat the patch with a 2 part epoxy and pop rivet it in from the inside. Epoxy and fold the bottom under the wheel well lip and pop rivet it in place. Fill any voids with epoxy. It will shed water more like shingles that way, but if you are traveling, it's more like a car wash in the wheel well.
