Where to mount ground wire on electric brakes
Discussion in 'Tires / Brakes / Bearings / Axles' started by razcob, Nov 18, 2018.
  1. razcob
    razcob Member
    92
    Jan 4, 2018
    Powhatan, VA
    I have a new Dexter torsion axle with electric brakes.
    Where is the best place to ground the magnet wire in the electric brake hub?
  2. tombiasi
    4,710
    537
    Anywhere on the frame with a clean connection.
    Since they are a critical component I ran a separate ground wire to the battery.
    WrkrBee likes this.
  3. Raycfe
    13,941
    939
    DITTO ^^^^^^^
  4. razcob
    razcob Member
    92
    Jan 4, 2018
    Powhatan, VA
    Thanks. This is a followup. How come the new Dexter Axle has 16 gauge wire and the 7 pin is blue 12 gauge?
  5. tenttrailer
    2,928
    201
    Jul 18, 2013
    Thornville, OH
    Frame or run a white wire back to the White wire on the 7 pin connector
  6. tombiasi
    4,710
    537
    A two wheel axle is fine with 16ga. The connector allows for trailers with more wheels.
  7. tenttrailer
    2,928
    201
    Jul 18, 2013
    Thornville, OH
    That's all each brake assembly needs. 2 brakes you would want to run #14 to the first brake wire and daisy chain to the second. 4 brakes I think you want to use #12 and do the same daisy chain to the others.
  8. roybraddy
    roybraddy Well-Known Member
    1,792
    498
    Mar 23, 2016
    King George, Virginia
    Each BRAKE MAGNET will draw around 3AMPS DC CURRENT WHEN HIT WITH 12vdc... This relates to 6AMPS DC current for each axle being used.
    I use one of those frame drlll tap kits from local auto stores (PEP BOYS)…
    This will allow you to have a treaded bolt hole in your POPUP frame. Then I use a star washer to bite into the frame and never have more than one or two cable ring terminal per Tap... I always spray the whole connection with RTV to keep it from rusting after installing bolt and cables ring terminals...
    Google image
    Roy Ken
  9. silvermickey2002
    4,342
    214
    Sep 11, 2008
    Morris County, NJ
    When you ground it to the frame make sure to clean the spot to bare metal to insure a good ground.
