Which part is this?
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by Father_Redbeard, Sep 28, 2018.
  1. Father_Redbeard
    Father_Redbeard New Member
    21
    Jul 12, 2018
    2005 Fleetwood Victory
    I just noticed that the circled part in the picture on my PUP is trashed underneath the trailer. I found this diagram on colemanpopupparts, but it's not labelled and I don't know what it is or what I would need to order to replace it.
  2. jmkay1
    3,811
    848
    I believe it is called the flexfill hose. Mine was completely disinigrated as well. The previous owner even cut a portion of it off on mine. However I just discovered they do have multiple sizes and syles out there, so you will need to see if you can find the size you need. I got the wrong size by a smidge and used the all rib flex hose vrs the type I currently have. I found the ribs caused me a lot of problems getting it over the tank and giving me a tight seal. I found mine at an RV store, nut seen it on Amazon as well.
  3. Father_Redbeard
    21
    Jul 12, 2018
    Ah, so this is the hose that you fill the fresh water tank with?
  4. joet
    3,669
    554
    Lowes or Home Depot
  5. jmkay1
    3,811
    848
    yes that is correct. If you don't plan on using your on board tanks you can get away with not needing it.
