12-volt mattress pad
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by pianewman, Dec 5, 2007.
  1. pianewman
    pianewman Ft. Worth, TX
    603
    Aug 30, 2006
    Arlington, VA
    Just received 2 "World's Safest Warming Mattress Pads" from Cozy Winters. The claim is that 12-volt heating coils are safer than 120-volt. (It still plugs into the 120-volt outlet, then converts to 12-volt). I'll try them out tonight (down to 28-degrees) and see if they produce enough heat to warm the sleeping bag.
    Anyone else using these?
    pianewman
    2002 Fleetwood Santa Fe
    2007 Honda Odyssey EX-L, Reese 400 WDH, Honda AT and PS coolers, Airlift 1000s with Dual-gauge compressor
    Scangauge II
  2. Girl-Trapped
    Girl-Trapped New Member
    216
    Mar 7, 2007
    Let us know how they work!
    We have our winter campout with Indian Princess in January and although it's not nearly the winter most of you experience, it can be cold at night. A 12 volt heater pad to augment our electric heater might just do the trick!
    01 Jayco Heritage Laurel
    04 Pilot EXL-NAV
    One wife
    Three daughters
    Big dreams
  3. CurtisH
    CurtisH Member
    47
    Sep 14, 2007
    Waco, Texas
    I too am interested in knowing how these worked out.
  4. tampajim
    tampajim New Member
    383
    Feb 26, 2006
    Brandon, Florida
    I haven't tried this particular model, we use a 12v heated mattress pad from Sears and it works great since most of the cold air comes from under the bed.
    ____________________________________
    Jim (DH - 60, DW - 60, DD - 98, DD - 00)
    2004 Fleetwood Sequoia
  5. Tikker
    Tikker Member
    313
    May 9, 2007
    Humboldt, Saskatchewan
    it's really not recommended to use the heating pads in conjunction with electric blankets
    at least that's what mine said on the label ;)
  6. pianewman
    603
    Aug 30, 2006
    Arlington, VA
    "Driveway" camped last night, temp dropped to 20degrees. Here's my set-up: Holmes "Whisper Quiet Twin Ceramic Heater" (HCH 4953..Walmart $38) pointed right at me.
    12volt mattress pad (Cozywinters.com) on high.
    10-year-old Kelty "Ridgeway" (+20f)(Costco) sleeping bag.
    "Popup Gizmo" under the bunk-end mattress, foil side up.
    Inside camper 51 degrees, outside 20 degrees.
    Mattress pad, on hi, worked, but barely kept up, although I made it work hard, as I was in the sleeping bag. Tonight, I'll try a flannel sheet over the pad, and sleep directly on that.
    My nose was very cold, but otherwise, it was more than adequate. If my wife had been with me, I'm sure it would have been better.
    My concern now, though, is folding the camper up in sub-freezing temps. Vinyl windows are rather stiff. Any thoughts? I'll also post the same question elsewhere.
    pianewman
    Scangauge II
  7. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    Sounds like the trip I had a few weeks ago! Didnt have a thermo to see how warm or cold it was in the pup, but my nose and exposed ear were COLD... Also had the heated mattress cranked, an electric 1500w heater aimed at us, and the far bunk curtained off being that nobody else was with us.. It was WARM compared to outside, but the canvas seems to let in some cold... I dont have gizmo's or anything yet, but plan to soon...
    As for folding it up, crank that heater for a while, with the top of the end bunk screen undone, i mean barely undone, so it can vent some, and id think you should be fine to fold it up then. PLUS, it will be somewhat warm due to the heater having been run inside.. Good luck, let us know how it goes!
    kevin
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp"> 2004 Rockwood 1940 LTD
    <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle"> 96 Cherokee 2dr 4x4 5spd
    <img src=../Images/icons/icon_smile_hardhat.gif border=0 align=middle alt="Major Mods"> 1996 Rockwood PUP-For Parts! (now a flatbed!)
  8. mostlyok
    mostlyok We're Mostly OK!
    1,077
    Jun 5, 2005
    Sarasota, Florida
    Flip the gizmos over. ther silver side will reflect heat into the bedroom, not send whatever heat bouncing off the roof. We have found this out on our own.
    Heidi & Paul <img src=../Images/icons/icon_smile_camping.gif border=0 align=middle alt="Camping"> are MostlyOK http://community.webshots.com/user/mostlyok
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp"> '94 Starcraft Space Flyer
    <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle"> '05 Jeep Wrangler Unlimited
    If its got zippers and Velcro it's got to be fun!
  9. pianewman
    603
    Aug 30, 2006
    Arlington, VA
    Hey mostlyok,
    Thanks for the input.
    In cold weather, you put the gizmos on the roof of the bunk end, foil side down? I thought it would do more good under the mattress, foil side up.
    Have you ever compared both versions? Anyone else have a thought on this?
    pianewman
    Scangauge II
  10. Hothand
    Hothand New Member
    112
    Sep 21, 2007
    If you build your own gizmos, you can actuall build a "sock" that goes all the way around the bunk end, secured with velcro.
    (gotta take some pix of this. I keep telling me and telling me.)
    the thermostat of a 1500 watt heater will actually shut it off even when the temp's in the single digits and have never needed an electric mattress thingie. As for the canvas/windows being stiff, if you make turing off the heater the last thing before cranking her down... not a problem.
    Hothand '47
    DW '46
    '87 Coleman Chesapeake
    '99 Ford Ranger
  11. Tikker
    Tikker Member
    313
    May 9, 2007
    your mattress and the bunk itself are a lot thicker than the canvas, so I'd definitely use the gizmo over the canvas
  12. pianewman
    603
    Aug 30, 2006
    Arlington, VA
    3200 mile trip from VA to TX, temps down to 25f at night. Heated mattress pads, with heated blankets, were extremely successful. Here's what we did.
    Set up camper.
    Fire up propane heater, turn on mattress pads/blankets, 1500-watt space heater.
    Go to c'ground facilities to brush teeth, etc (plumbing in pup remained winterized, except for Thetford).
    By the time we returned to pup (maybe 10 minutes), inside toasty warm, with bunks warm as well.
    Turn off propane heater...not needed after initial warm-up.
    No problems folding pup. The vinyl windows complained a bit, and I was very gentle with them, but never felt threatened.
    pianewman
    Scangauge II
