1976 Jayco popup manual
Discussion in 'Camper Manufacturers & Manuals' started by The McIntyres, Oct 25, 2019.
  1. The McIntyres
    The McIntyres New Member
    Oct 25, 2019
    We have recently brought a 1976 Jayco fixer upper pop up, would love to see the manual for this type of camper, first on the list is the cable on one side is broken so that needs to be fixed. Any Info would be great!
    Thank you
  2. Raycfe
    17,005
    2,587
    An owners manual is next to useless.
    Ask questions ...... this portal is a living service manual.
    This should apply to your 1976. If the winch is in the curbside front corner of the camper, remove the cabinet or step that goes across the middle of the interior front panel. You will need a number one and two square drive screwdriver. The first place to check the cables is under there.
  3. PopUpSteve
    PopUpSteve Administrator
    19,570
    2,192
    Dec 22, 2002
    Malvern, PA
  4. WrkrBee
    WrkrBee Well-Known Member
    4,266
    1,924
    Welcome to the Portal from South Carolina.
