1980 starcraft do i have surge brakes?
Discussion in 'Tires / Brakes / Bearings / Axles' started by swillotter, Aug 22, 2007.
  1. swillotter
    swillotter New Member
    Aug 22, 2007
    hi all i've got a 1980 starcraft, was wondering if this thing had surge brakes? how can i tell, thank you much. would love a link to a repair manual for this thing
  2. jerkin
    jerkin New Member
    32
    Jul 23, 2007
    Just look to see if there's a master cylinder on the tongue somewhere or pull a wheel.
  3. swillotter
    Aug 22, 2007
    thank you , yes there is a master cylinder on the tongue. surge brakes right? also this PUP has an 8 pole connector which nobody seems to have an adapter for to go to my 4 pole on my F-250. it has four holes on top and two holes and two pins on the bottom. wondering what i should do? i am thinking about just getting magnetic lights as that would be the easiest thing to do, i'm not to concerned about not having power inside as i don't have an electric water pump but i do need brake and turn signals, wondering if anyone had any ideas...thanks again
  4. cruising usa
    cruising usa New Member
    508
    Aug 19, 2006
    I am no expert, however, I do not believe the 8 pin is available. I would consider converting to a 7 pin connector. That way if in the future you add a battery to the PU half the work is done for the charge line. Search the etrailer.com site for electrical wiring. You will find wiring diagrams to help with the wiring.
    Ken
    Me 58,DW
    04 Starcraft 2409
    97 Ranger TV
    Ontario NY
    Edited by - cruising usa on August 23 2007 11:10:37
