1986 Starcraft SLE 17 interior lights
Discussion in 'Wiring' started by Kwfixer, Feb 15, 2018.
  1. Kwfixer
    Kwfixer New Member
    Feb 14, 2018
    Elgin, SC
    I was wondering if anyone has had problems running the interior lights from just the wiring harness connected to the tow vehicle. My camper doesn't seem to want to turn on when connected to the vehicle, only works when connected to shore power.
  2. J Starsky
    J Starsky Well-Known Member
    967
    822
    Aug 3, 2017
    East Central MN
    My old gal only works off the battery or shore power. There are more wires than the flat four I use on the tongue plugin.
  3. Fless
    Fless Active Member
    971
    211
    Aug 14, 2012
    Colorado
    @Kwfixer, help us with a few more clues:
    1. Is there a battery in the circuit (typically on the trailer tongue)?
    2. When you attempt to run the lights using the TV (tow vehicle), is your TV running?
    2a. If TV not running, is the accessory conductor in the TV's connector live? (hint: voltmeter time)
    3. Are all of the fuses good on the converter in the trailer's cabin?
    _
