1987 Chesapeake roof
Discussion in 'Roof/Floor Repair & Maintenance' started by Hogeyphenogey, Aug 2, 2021.
  1. Hogeyphenogey
    Hogeyphenogey Member
    85
    May 3, 2014
    Bought a Chesapeake with an aluminum roof that sags and has a crease with a small opening in the center of the crease. Is there a way to pop the top upwards? I really don’t want to rebuild the whole roof. If it comes to that I may sell. I put a piece of flex seal tape over the hole to prevent water leaks. I’m wondering about using some sort of reinforcement as well but I don’t want it to be heavy up there. Any help is appreciated
  2. Jkoht
    Jkoht Active Member
    101
    82
    Aug 10, 2020
    I'd tell you to make an additional bow sprit out of electrical conduit, or even pvc, but if your solution to a hole in the fabric is tape I don't know if you're up to the task.
  3. Hogeyphenogey
    85
    May 3, 2014
    Well, thanks? I’m not sure what you mean about a hole in the fabric. I have a crease in my roof with a small crack on a camper I just bought. While it’s in the driveway, I covered the small crack with flex seal to stop water intrusion while I’m looking for a solution to fix the whole roof but thanks for your constructive comment.
  4. Hogeyphenogey
    85
    May 3, 2014
    Has anyone redone or repaired an aluminum roof that can actually assist?
  5. Sjm9911
    10,765
    8,145
    Never done it but pictures of the roof in question may help. Hard to fix without knowing the extent of the bow. If its waterlogged allready, you will probably need to rebuild it.
