1988 Rockwood Popup Lift access?
Discussion in 'Introduce Yourself' started by Keith W Whitehouse, Jun 21, 2020.
  1. Keith W Whitehouse
    Keith W Whitehouse New Member
    Jun 21, 2020
    Hi,
    Keith W here from Tulsa, Ok.
    I have a 1988 rockwood popup with a malfunctioning lift. Front goes up, back does not go up when cranking.
    How do I access the area where the crank arm attaches?
    Thank you
    Keith
  2. WrkrBee
    WrkrBee Well-Known Member
    3,551
    1,510
    Welcome to the Portal from South Carolina. Use the Portal search function. You should find some threads to help you.
  3. kcsa75
    kcsa75 Well-Known Member
    3,641
    1,843
    Sep 9, 2013
    Kansas City
    Hi Keith. Welcome to the forum from Midway USA.
  4. PopUpSteve
    PopUpSteve Administrator
    19,181
    1,947
    Dec 22, 2002
    Malvern, PA
    Welcome to PopUpPortal
  5. bobinfleet
    bobinfleet Well-Known Member
    825
    332
    Sep 2, 2011
    Hampshire UK
    Hello and welcome from Hampshire UK[GBR], have you checked the resources tab?
  6. PA-Scott
    PA-Scott Active Member
    197
    77
    May 4, 2020
    Pennsylvania
    Keith, Hello and Welcome from central PA!
    It's already been said but search the threads, I've crossed a few on lift's in the past month or so.
  7. Keith W Whitehouse
    Jun 21, 2020
    Thank you for the replys, I will dig around and see what I can find.
  8. Keith W Whitehouse
    Jun 21, 2020
    Greetings,
    I have managed to access the lift assembly in my 88 rockwood popup. As you can see the circled gear is stripped.
    A. What typically causes this?
    B. How do I remove and replace it?
    Thank you for your help
  9. WrkrBee
    3,551
    1,510
    A. Cheap manufacturing methods since cost cutters are in charge. The worst gears are stamped due to tooth engagement clearances used. Then they get the bright idea to rivet them together for more surface area, but nothing really lines up. Then nobody greases the shoddy fitting gears.
    B. What does the top and back of the gear assembly look like?
  10. Keith W Whitehouse
    Jun 21, 2020
    Hi, thanks for replying,
    Over all the camper is in pretty good shape, it does have a little bit of rotting in the top left corner of the top. the gentleman that had it before me put additional bracing on the inside to help support the top. He attached the bracing to the existing push polls that support/raise the top.
      File size:
      20 KB
  11. WrkrBee
    3,551
    1,510
    So a band-aid instead of a repair. Did he fix the leak that caused the rot?
  12. Keith W Whitehouse
    Jun 21, 2020
    yes,
  13. Keith W Whitehouse
    Jun 21, 2020
  14. Keith W Whitehouse
    Jun 21, 2020
    The rest of the assembly looks good, all the gears feel very firm, no slack anywhere, teeth look good.
  15. WrkrBee
    3,551
    1,510
    Guess I was asking for pictures of the assembly top and back. It'll come apart someway. Something holds it together. I can't tell from the one picture. It'll probably have to come out to be disassembled. Can you get parts for the winch, before pulling it out?
  16. Keith W Whitehouse
    Jun 21, 2020
    So far I am striking out on parts. Its to old. I am going to call an RV salvage tomorrow.
  17. WrkrBee
    3,551
    1,510
    Take the winch apart and make your own gear. It's not going to be any worse than the stamped gear, but will probably be better. I'd hate to loose a camper over a gear.
  18. nineoaks2004
    7,860
    3,470
    Dukes, Fl
    Welcome from Dukes Fl. Good Luck with the repairs and happy camping
  19. Keith W Whitehouse
    Jun 21, 2020
    Thank you,
    I am striking out on my repair and my camper serial number is incomplete. I only have 16 digits and I need 17. I have cleaned both sides of trailer tongue and nothing is stamped anywhere. Does anyone have an old 1988 rockwood pop up serial to compare mine to.
    1RKTC040J1000169 is what I have.
    Thank you,
