1990 Starcraft Meteor Brake Question
Discussion in 'Tires / Brakes / Bearings / Axles' started by Ryoukoe, Jun 13, 2012.
  1. Ryoukoe
    Ryoukoe New Member
    113
    Jun 12, 2012
    I downloaded the owners manual for my trailer from this website and it talked about brakes but when I talked to the seller he said they were none. Is this something I pay extra to have installed or do not every camper come with the ability to have them?
  2. Raycfe
    17,005
    2,587
    Brakes do make a difference. Now with that said ............ Make a plan of attack for your N2U Meteor. The brakes are an easy thing to do and I wouldn't put it on the top of your to do list. Do any major repairs first and the brakes and tires when it is ready for the road. If you search "brake flange" and your axle has them, brakes are a bolt on. You will also need a brake controller for your TV (tow vehicle). But I suggest a new pupper have a plan.
  3. Rodger D.
    Rodger D. New Member
    748
    Sep 29, 2010
    Hello There
    I went from an 27 foot AirStream that has Electric Brakes to our
    1981 Starcraft. The Starcraft has nuthin in the manner of brakes.
    From this site I got The Dealer's Brochure and it showed that in
    1981 it was an Pay More Option in our area ... for brakes.
    Out of this ... http://www.popupportal.com/index.php?topic=47369.msg396872#msg396872
    I got brakes for The Pop Up.
    Look on the rear of your wheel mounting and see if you have an flat metal
    Plate/ Pad with an hole in each corner of it. This is for mounting The
    back of The Brakes. Look at the max weight of your unit. This will be the
    size of the brake unit to get for it.
    While this is happening stop at any WalMart or the sort to get any brand of
    Trailer Brake Controller. They are ther same if you are going to be using a
    Lawn Mower Trailer to an Horse Trailer ( this part is where some get vocal
    and say that you must use this Model and Brand vs what others are using ).
    If you are shown an Flat Four Vehicle Trailer Plug remember that you can
    not use it since there is no Blue Electric Brake Line.
    Rodger & Gabby
    FltSgt@msn.com
    COS
  4. Ryoukoe
    Ryoukoe New Member
    113
    Jun 12, 2012
    Thank you that was so helpful. I was not sure what to look for in order to figure out if I even had a break option on my PUP or not.
  5. barb_dave
    barb_dave Active Member
    1,731
    Jul 22, 2007
    Wisconsin
    Ryoukee, the link below should be of some help. It is from when I installed brakes on our camper. On the axle you'll notice the square flanges used to mount the brakes to the axle. If you don't have the flanges they can be purchased and welded into place or you could replace the axle with one that has flanges
