1993 Coleman Destiny Roanoke abs panel repair
Discussion in 'Miscellaneous Repairs & Maintenance' started by Asupremepop, Oct 18, 2019.
  1. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    253149CE-73C0-4AED-AE13-A62AE71383D1.jpeg I had a large piece of the rear panel fly off of my pup on the way home from our latest trip. I figured I’d try and fix it rather than replace it. (Mainly because I couldn’t find one anywhere nor was I willing to pay for a replacement. )I believe I succeeded in this repair, however it was not an easy process. I did save a boatload of money doing it this way. I paid $17 for a 12x24” piece of white abs and $8 for pint of MEK.
    Here’s the damaged panel.
  2. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    I started with making a form.
  3. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    FDD71FA6-9EA9-4E67-9678-5132013936C2.jpeg 27D8DEED-ECFF-4C68-90AB-B4933C065892.jpeg Then I started to form the abs with a heat gun. After adding some clamp holds to the form.
  4. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    F3F46953-350C-45B7-8A16-C86CAF86A489.jpeg Got it into the general shape.
  5. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    239682F7-9C57-46B8-9983-4031C6B77E6A.jpeg 0B13EEE5-100F-4482-90C6-3AD6D69B8FE5.jpeg Cut it to match the existing abs
    Cutting abs is easy just score it with a blade and bend it at the score mark till it breaks. (Don’t try scissors)
  6. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    AA8C926C-7CF8-4EDE-81EE-C67EA4D32182.jpeg 7F31DEFF-D06A-47DC-ACD8-66EEE052E099.jpeg I mixed up some MEK and scrap abs from cutoffs. This took a chunk of time due to having to wait for the abs to dissolve and get the proper consistency.
  7. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    1CDB7AA8-A13F-4D74-9835-64C66631D4AF.jpeg 3AE3A1FB-3752-46FE-BDA8-3030B3568EC3.jpeg C4BE7CCF-EA3C-4080-B07F-DDA5375F29D6.jpeg 9FD0F054-A7C8-4007-80A3-4DAB8ACE4EEA.jpeg D0845A39-8E0A-4FB2-9CDA-F24258426A01.jpeg I used this concoction as a glue to attach more scraps with clamping pressure to adhere the piece to the panel.
    Again a big chuck of time here. Basically wait about 10 minutes per piece. I also utilized the heat gun here for some parts due to the sometimes uneven placement. Just heat it up till it’s ply able and jam it into the area to “form” it. Then add MEK mix and clamp in place.
  8. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    Then I flipped the panel over and...walla! Ugly right? (Yet so beautiful.☺️) ED2995B9-1D8B-40CD-B0BB-3A62898F56F1.jpeg 0F982579-AE8F-4DDC-889F-049C36630EF6.jpeg
  9. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    4E7784DD-A11E-429E-BCC1-35DBDD938C16.jpeg E6D6BEBD-3DA9-4E88-80BD-9F98D4CE96E9.jpeg This is where the magic mix yet again comes to the rescue. I simply filled the holes and cracks with the MEK mix and it solidifies in mere minutes. I then sanded it smooth.
    I did this in several coats to fill holes and cracks.
  10. Sjm9911
    6,921
    4,308
    Wow ,looks good. But people will hate you for your ingenuity! Looks too good. I hate you! [:D]
    Pleaee show where tou got the abs pannel! People will want to try this.
  11. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    3D12E7EB-D199-47A4-AAA4-CF8D0A46987E.jpeg 79FC2929-1CE9-4C64-A5FB-87E72BEE25B1.jpeg And finally. Paint.
    Not perfect by any means but considering the alternative and cost I’m pretty happy with the results.
    Feel free to comment and critique if you would like.
    I hope this post helps someone somewhere along the line.
  12. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    You bet thanks. I got the abs panel on eBay
    WHITE ABS PLASTIC SHEET 1/16" VACUUM FORMING RC BODY HOBBY YOU PICK SIZE^
  13. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
  14. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    It was cheaper than I said it was. Bonus
  15. Sjm9911
    6,921
    4,308
    It works , thanks.
    Asupremepop likes this.
  16. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    F252D7C8-80E8-45ED-9F2E-8F527063C039.png Before I made the magic mix I tried this stuff. DON’T!
    It may work on abs tight fitting pipes but not for this job. It takes way to long to cure compared to the magic mix.
    Anyone know a plumber that could use this stuff?lol
  17. Asupremepop
    Asupremepop Member
    44
    18
    Oct 11, 2018
    Wisconsin
    372A9E67-41E4-4F5E-AE8A-BB1B2FB6A3C9.jpeg 609BE5AD-94CE-4C5E-BC34-9960C6170593.gif
    kcormier19 and Sjm9911 like this.
