1995 jayco popup truck camper how do I adjust roof to level?
Discussion in 'Vintage & Off The Wall Campers' started by Wyliefox, Sep 8, 2020.
  1. Wyliefox
    Wyliefox New Member
    Sep 7, 2020
    How do I adjust roof level? Front is 1 1/2 inches lower than back end. I just replaced the winch cable. Roof lifts up fine, but the front sags.
  2. Wyliefox
    Wyliefox New Member
    Sep 7, 2020
    I was advised to look for debris in the lift columns, or a worn pulley. I found mud dauber nests and active wasp nests in that area (they accessed the interior through a small air hole next to the water filler hose). This was right over the spring that pushes the lift rod that raises the roof. I would never have found the lift column, or the Spring or the mud if not for this website. Thank you for your advice. I greased the spring, lowered then raised the toof and measured. All four posts were exactly 21”.
    myride and Steveo4090 like this.
  3. PopUpSteve
    PopUpSteve Administrator
    19,570
    2,192
    Dec 22, 2002
    Malvern, PA
    Sound like you got it working, great job.
