1997 starcraft starflyer HELP
Discussion in 'Heating / Cooling Systems' started by Nikki, Jul 21, 2019.
  1. Nikki
    Nikki New Member
    Jul 19, 2019
    Hey all!!
    My heater stopped working suddenly and I am at a loss. Thermostat seems hooked up correctly (although I cant find a picture online) Circuit breaker fuses are all good and switches are all on. Used it a month go and heater was just fine. HELP!!!!
    1380ken likes this.
  2. eoleson1
    eoleson1 Well-Known Member
    2,269
    693
    Jul 5, 2011
    Macomb County Michigan
    Does the blower come on?
  3. Nikki
    Nikki New Member
    Jul 19, 2019
    Nope. Nothin.
  4. eoleson1
    2,269
    693
    Jul 5, 2011
    Check power and ground at the thermostat. If you take off the cover, you should see a screw terminal marked "R" and a terminal marked "C." You should have 12 volts across those two.
  5. Nikki
    Nikki New Member
    Jul 19, 2019
    Okay thanks!
  6. neighbormike
    2,382
    1,803
    Oct 6, 2012
    WI
    Do as @eoleson1 suggests and also check the galley kill switch - both are prone to failure.
  7. Nikki
    Nikki New Member
    Jul 19, 2019
    where is that?
  8. neighbormike
    2,382
    1,803
    Oct 6, 2012
    WI
    There should be a kill switch on the flip-over galley that gets depressed (not sad) when the sink is in place.
    Nikki and Sjm9911 like this.
  9. BillyMc
    BillyMc Well-Known Member
    1,243
    601
    Mar 25, 2018
    Had that happen with our Starcraft Starmaster 1224. Turns out that something was shoved to the back of the cabinet under the sink and pulled a wire connector from the galley switch.
    Nikki likes this.
  10. neighbormike
    2,382
    1,803
    Oct 6, 2012
    WI
    Similar issue on my '94 Stardust.
    Nikki likes this.
  11. Nikki
    Nikki New Member
    Jul 19, 2019
    Oooh okay!!
    Thanks so much!!
