1998 jayco eagle 12s SO restoration and partial rebuild
Discussion in 'Camper Restoration Projects' started by The_scamper, Aug 8, 2019.
  1. The_scamper
    The_scamper New Member
    24
    Jul 16, 2019
    I Recently purchased a 1998 jayco eagle 12 so for a couple hundred dollars. The roof had leaked and collapsed and caused extensive water damage along with allowing rodents and snakes by the look of it in. The canvas was mildewed, rotted in places, smelled of urine and had holes chewed in it. The PO had the foresight to keep the cushions in the house at least ,so those are in like new condition as well as the cabinetry. I do however plan to replace the cabinets only slightly more work and 1/2 plywood is lighter and more durable than the particle board boxes. After doing a more thorough inspection, I found the slide out floor is rotted. Some plywood and it should be a inexpensive repair. I also found the rear framing and wooden panels under the aluminum where tail lights, electric, spare tire mount etc. I decided to start with the top since it's the most important peice.
    hq308, megcabra and PopUpSteve like this.
  2. kcsa75
    kcsa75 Well-Known Member
    3,097
    1,447
    Sep 9, 2013
    Kansas City
    Good Luck on the repairs/renovations.
    Here's a photo of our '98 Eagle 12.
    txmnjim likes this.
  3. nineoaks2004
    7,463
    3,205
    Dukes, Fl
    Good Luck with the project and Happy Camping
  4. The_scamper
    24
    Jul 16, 2019
    Inside damage
  5. The_scamper
    24
    Jul 16, 2019
    Rear panel damage
  6. The_scamper
    24
    Jul 16, 2019
    Looks like a mouse Nest. Found a dead mouse in one cabinet and a couple snake skins throughout.
  7. The_scamper
    24
    Jul 16, 2019
    Rear water damage
  8. The_scamper
    24
    Jul 16, 2019
    Canvas damage
  9. The_scamper
    24
    Jul 16, 2019
    The rebuild
  10. The_scamper
    24
    Jul 16, 2019
    Poptop new frame build
  11. The_scamper
    24
    Jul 16, 2019
    Frame attached ready for sheeting. 1/2" plywood with 2x3 stringers. Added unistrut later on as the 2x3 s were sagging
  12. The_scamper
    24
    Jul 16, 2019
    1/2" sheeting installed
  13. The_scamper
    24
    Jul 16, 2019
    Marrying unistrut fixed the sagging. Added about 60lbs to the top. As far as I can tell the winch is rated for 800lbs so I didn't even get close to half capacity even with ac unit
  14. The_scamper
    24
    Jul 16, 2019
    Ribs and ac framed
  15. The_scamper
    24
    Jul 16, 2019
    Spray foam radius on front and rear
  16. The_scamper
    24
    Jul 16, 2019
    Shelf for spray foam
  17. The_scamper
    24
    Jul 16, 2019
    Belt sanded cured for for radius
  18. The_scamper
    24
    Jul 16, 2019
    another Sanded radius
  19. The_scamper
    24
    Jul 16, 2019
    Rear rebuild
  20. The_scamper
    24
    Jul 16, 2019
    1/2 plywood
