1999 Niagara sway bar success
Discussion in 'Tow Vehicles, Hitch & Towing' started by Spawndn72, May 8, 2017.
  1. Spawndn72
    Spawndn72 Member
    65
    Jul 29, 2016
    Towed my pup all last year with no sway control and it did ok until you hit 65mph and then it immediately started swaying.
    Bought a Curt friction sway bar and got it installed this weekend. Night and day difference. Tows perfectly. I got it up to 75mph just to see and it never even tried to sway. Will be keeping it below 65mph in the future, just wanted to see how it did if the speed creeps up a little.
    So if you have thought about a sway bar, I highly recommend getting one.
    theseus likes this.
  2. theseus
    theseus Centerville, OH
    2,895
    435
    Feb 6, 2007
    Centerville, OH
    When you get a larger pup, you suddenly find that sway control is a wonderful thing. I have had it on my previous camper and current one. It makes the ride less stressful.
    jmkay1 likes this.
  3. Halford
    Halford Well-Known Member
    3,563
    566
    Sep 28, 2011
    Santa Clarita, California
    I have 2002 Niagara... do not need sway control since I put heavier stuff in cargo storage or toward front part of camper. I never had swaying problems. Make sure that the Niagara or any popups are level while towing and heavier things are always up in front toward tongue. I was up to 70 last weekend and no swaying issues (yes, I have radials).
  4. Spawndn72
    Spawndn72 Member
    65
    Jul 29, 2016
    Apparently they moved the floor layout around to get more weight up front beginning in I think 2001. The models before that have sway problems due to the layout. I load everything I can get into the front cargo box and it still sways without the swaybar. With the swaybar it is a completely different animal.
    theseus likes this.
  5. Halford
    3,563
    566
    Sep 28, 2011
    I see... ok try put all your cast irons up in front. [:D]
  6. mstrbill
    mstrbill Active Member
    692
    145
    Mar 17, 2013
    Austin , Texas
    That happened for the 2004 models, same year the separate "plastic" trunk replaced the integrated storage trunk.
