1999 Starcraft Meteor Lift system
Discussion in 'Miscellaneous Repairs & Maintenance' started by gbberton, Mar 7, 2011.
  1. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    Does anyone know where I can get a diagram of the lift system on my 99 Starcraft Meteor? I thought I would lube it last Saturday, but all the moving parts seem to be under a steel plate held on by a bunch of bolts. Help!!! It seems to take a lot more effort to raise it than you would think it needs, but goes back down pretty easy.
  2. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    Starcraft ... call them ... ask for their tech services.
  3. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    Hi Guys: I did some digging on the internet and came up with some info on the lift system that might be helpful to others here. This is the same lift system as mine. The pics are not very good, but there is a lot of good info there.
    http://www.wikipopup.com/images/Starcraft_1985___Newer.pdf
