This, you should have a hook up on the outside of the camper or a place to run the hose. Usually.You have a low pressure stove. If you actually did connect it directly to a tank of any size you would have a blow torch. Short answer, not a good idea..
Amazon has a wide variety of replacement knobs. Measure the shaft accurately, and google “universal stove knobs”.
Good to know! Thanks for the info.these stoves need regulated input pressure so any 'adapter' would need a low pressure regulator.
"Adapter" with regulator
QD - low pressure
another 'adapter'
GAS GRILL ADAPTER KIT
What do you think about This one?these stoves need regulated input pressure so any 'adapter' would need a low pressure regulator.
QD - low pressure
another 'adapter'
