$200 Portable Diesel Air Heater - 17,500 BTU
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by hour, Mar 11, 2018.
  1. hour
    hour New Member
    Aug 7, 2016
    I had been interested in diesel air heaters that people are installing in Sprinter vans and that truck drivers use to stay warm. The last time I had really looked in to them the cheapest offerings to be had new were in the $500 range for the Planar brand, and double that for Espar/Webastos.
    Fast forward 1.5 years and I find that a bunch of clones are being produced and sold on eBay for $200. I have a 2017 pop up with a brand new Suburban furnace that works fine, sweats me out in 10 degree weather even, but I figured this would be cool to have and I could heat tent(s) with it too.
    Parts
    $200 eBay 5kw diesel air heater
    $38 Dewalt DS300 tool box
    $7 Spectre 8148 3" duct mounting plate (for the cool side)
    $15 Spectre 81413 3" maf sensor plate (metal, for the hot side)
    $0 Metal plate found in garage for exhaust and inlet holes
    $0 Exhaust header wrap scraps (not necessary)
    $260
    Stats
    17,500 BTU
    200+ degree output
    20lbs assembled weight including tool box
    9 hours per gallon on HIGH non-stop, consuming 2 amps 12v dc
    First, these are safe to have mounted inside and countless vans, RVs, and trucks have these setups. The exhaust and combustion intake don't contact the air being circulated through the unit. A large aluminum heat sink is inside, which heats up and air is blown over that.
    These are also camp site friendly, the exhaust does sound a bit like a jet engine on my 2 foot pipe but you could buy a longer 26mm flexible exhaust pipe or even a small engine muffler. Espar and Planar both have 24-26mm mufflers for sale, too. There's 30 seconds of diesel smell out of the exhaust until it gets running, and then its hardly noticeable.
    No need for elaborate steps. I used a 3 1/8" hole saw and drilled two holes on either end of the Dewalt box. I used some aluminum bar and scrap to mount the unit and ensure it wasn't capable of moving. I cut out a section of the front of the tool box and mounted a metal plate with two holes drilled in it for intake/exhaust. This ensures that nothing starts to melt.
    The cloud is e-cigarette in first pic, not smoke :)
    And outlet temp -> exhaust temp (extremely hot!)
  2. jnc
    3,920
    1,168
    Oct 1, 2014
    South Central New Hampshire
    Thanks for the Post.
  3. Wrenchgear
    3,221
    520
    Aug 5, 2010
    5 Star Eagle Camper
    Thats a lot of heat coming out of a small package, no doubt. So where will the tool box sit while running? Will you have it out on the tongue area and then duct the hot air inside, or will it be under a dinette seat, and vent the exhaust outside through a hole in the Pup body?
  4. mpking
    mpking Well-Known Member
    1,228
    280
    Jun 17, 2014
    Raynham, MA
    Where do you store the Diesel? Tank in a truck bed?
    Also, is that 2 amps per hour (when running continuously)?
  5. hour
    hour New Member
    Aug 7, 2016
    Not sure, it's safe to run inside and if I created some wedge shaped baffle (with double walled insulated exhaust pass through) I could set it by the sink or on the dinette in the pup and partially unzip one of the walls to reveal a similar wedge shaped void.
    If I felt like drilling through the floor I could put two three inch marine deck plates in, screwed up tight when not in use.
    Alternately I could create two wedge baffle things and run the cool and hot side in and out, requiring me to support the tool box at sink height, outside the camper.
    I'll post up pics when I figure out the best way to go about this.
    I'm just going to go with a 10L / 2.68gal jerry can for diesel and strap it to the truck's roof rack when I set off. Will definitely be enough for weekend / extended weekend trips in any weather conditions.
    It's 2 amps continuous load on the battery to run at high. Looks like my 19,000 BTU Suburban furnace consumes 2.7 - 3.1 amps so that works for me.
  6. inthedirt
    inthedirt Active Member
    870
    88
    Aug 28, 2012
    SW Montana
    Any updates on this?
  7. Sjm9911
    4,343
    2,171
    He was last on the site 4 months after he made that. Hope he didnt blow himself up!
