2000 Coleman Utah
Jim Keeling
154
Georgetown, Tx
Just completed total refurb. New roof,ele trical,led lights,roof gaskets,flooring,cabnet close, tires, air condition cleaning,greased bearings, storage box's front, custom decals, paint frame, Sealy mattresses, resurface counters, fold down table, Slideout dinner, clear title.$5600 20220821_104107.jpg 20220821_104001.jpg 20220821_103838.jpg 20220821_104107.jpg
Campingwithsix
New Member
Jul 27, 2022
Pm sent
David Lewis
Silver Supporting Member
Oct 29, 2021
22
Lake Wylie SC
Would like to see pictures and or other details of water heater mount in what appears to be poly tool boxes. That being said, I do like the refurb of the front end.
David
Sjm9911
12,224
If you take the water heater pannel off the rim , for lack of better word, just bolts in. They probably made a wood frame around the inside of the box, then drilled and bolted in the water heater. A block on the floor of the inside of the box , or foam will keep it level and from putting stress on the fasteners. But that just a guess. Should be an easy install.
David Lewis
Oct 29, 2021
22
Lake Wylie SC
The point of my post was what did the OP do about putting a high heat combustion source in a poly tool box. Yes, my heater is already in a plastic enclosure, but I wanted yo see how the OP dealt with the heater.
David
Sjm9911
12,224
Ok, sorry. Didnt know it was only for the op, maybe a dm would be more appropriate or a question just aimed at them? lol. Or Have a private conversation. I figure since they dont heat up much and are pretty much self contained, that it isnt an issue. Since mine is under a flammable foam couch. My point was to try and help, But what do I know?
Jim Keeling
154
Georgetown, Tx
Cut out with Sawzall. Trimed with Razor knife smoothed with sandpaper. Put block under body of heater. Cut holes thru plastic. 20220823_093402.jpg down to frame.self tapping screws. Pretty easy.. 20220823_093344.jpg
Jim Keeling
154
Georgetown, Tx
Bought from Amazon as returned items.1/2
price. Old storage box cracked to no repair. Coleman plastic was terrible. Roof removed and replaced with truck bed coating from Grizzly Grip. Good luck on projects. Here if you need help.
