2000 Viking Epic 1906 mystery poles and brackets
Discussion in 'Mystery Parts' started by Squeeker, Sep 14, 2019.
  1. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    these poles came with my pup, but I can’t figure out where they go.
    And what about these brackets? There are two of them, on the bottom of the tongue-side bunkend (queen bed) near the outer corner. There are none on the other bed. No idea what they are for, either!
  2. Sjm9911
    6,015
    3,462
    It looks as if the poles are your bunk end suports, they go into the brackets and back to the frame on the pup? The other one could go from the toung to the underside of the bed?
  3. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Nope, we have brackets for that already...
  4. Sjm9911
    6,015
    3,462
    Ok then im out! Lol , they do look like they go into those brackets.
  5. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    They really do. But there are no more spots to put them into!
  6. Sjm9911
    6,015
    3,462
    You have 4 poles on the one side?
  7. Sjm9911
    6,015
    3,462
  8. Sjm9911
    6,015
    3,462
    The toung side has 4 suport poles for the bed in that vid.
  9. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    HA! No kidding. Yup that’ll do. Now the problem is that I seem to have bent the other support poles because we weren’t using everything we should have been...
  10. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    What should I do about this...? It’s about an inch away from touching. I can’t believe I did this...
  11. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    The door closes better now (facepalm)
  12. Sjm9911
    6,015
    3,462
    Not sure , more pictures from other angles please.
  13. tombiasi
    5,713
    1,332
    The two poles on the left side of the picture support a bunk end. The flat side goes in a slot on the bumper and the other end goes in the bracket shown in the next picture.
    The pole on the right of the first picture I don't know. I have a Viking epic 1906 1998 and I don't have that.
  14. Grandpa Don
    Grandpa Don Active Member
    469
    227
    Sep 5, 2018
    Yep, they are for the front bunk. I have the same camper and same poles. Except for that long straight one. I have no idea what that one is for. The rear bunk does not have them and the weight capacity of that bunk is about 900lbs. ( if I remember correctly), and the front bunk is rated for 1,200lbs with the poles in place.
  15. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Here is a better pic of the bent poles.
  16. tombiasi
    5,713
    1,332
    My 1998 has poles for both bunks. It may have something to do with the size of the bunk.
  17. lostboy
    lostboy Active Member
    195
    67
    Nov 13, 2016
    Lakeville, MN
    Can you bend them back?
